How can i calibrate print head of pagewriter trim 1
When i start to print the record is too light
  • 790 Answers
It would help if you stated the manif. example. Phillips, HP, hewlett Packard. ect.
You should be able to find service information on the bottom of unit.
Posted on May 08, 2014
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Phillips pagewriter Trim1 not working
I have a proplem. When i press auto button then screen display error code 0204. thanks
Aug 28, 2009 | Philips Medical
Warning light keeps flashing
try to remove first all the paper in your paper tray.
then try to remove and then reseat the printhead and both of the ink cartridges.
then after the printer detects your printhead,the message is "New Printhead Detected, calibration require, load paper and press start" it will require you to to do a calibration.
hope this will help
Mark S.
Kodak AIO Technical Support Hotline 1-800-421-6699
Oct 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
THS error
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Jun 17, 2008 | TallyGenicom 2280 Matrix Printer
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
May 02, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
THS Error on warrantee printer tally serial printer
Apr 09, 2008 | Tally Matrix T2280 Printer
Zebra P330i
we have the same problem with our 330i !!
I updated the firmware to V1.16.11 and the printer drivers as well, then I started the cleaning process.
The printer has printed only 337 cards, so it is rather new.
All monocolor printed cards are ok (black, gold,...), but not even one 4color card.
It looks like the sync of the colorribbon does not work properly.
Is there a possibilty to check the sensors or are perhaps informations about the sensors on the cardtest-card ?
Thank you for any help !
Felix
Austria / Europe
Feb 06, 2008 | Zebra P330i Thermal Card Printer
jasbo
jasbo
