Question about Watches
E377 My E377 I have had for quite a while. Still a good timepiece. However, the composition back cover has disintegrated. Is there a replacement back cover available ?
5 Suggested Answers
SOURCE: I HAVE AN E377 RF
You need to remove the battery in order to stop the watch. You may have to short the watch's battery terminals after battery removal to discharge the internal capacitor, or just wait until it stops. Next you need to align all of the hands to the 12 O'Clock position. Follow the instruction booklet to do this, by pressing S1(top right button) and holding it until the watch starts to race forward (all 3 hands will move) then you can release it. When the hands reach approx. 11:59, press S1 again to halt the speeding motion. Now be very patient and make brief presses of S1 to advance the hands by one second at a time, until the watch shows all 3 hands at the 12 O'Clock position. When you have achieved this press S4 (Lower left button) for 1 second to confirm. (tedious beyond question)
After the LCD display switches on, set the time zone as instructed in the instruction booklet.
If auto synchronisation doesn't work and the watch moves to 12:03 or thereabouts, then carry out a manual sync, by following the instructions under 'Manual Signal Reception', or wait until the next auto update at 3am.
Let me know if you need any further help.
Ed.
Posted on May 20, 2009
escapement
  • 2334 Answers
SOURCE: I have the E377 and
You will find manual in my tips. Rate me, please..
Posted on Aug 05, 2010
  • 2501 Answers
SOURCE: Looking for Instruction Manual E377/E378 R/F Watch
You don't say what make of watch you have but I think they work in a similar manner to mine, so try this.
Press the mode button (usually the lower left one) and observe the LCD screen. Each time you press the mode button the screen should change to a different setting mode. Keep pressing it until you find one that allows you to set the hands (on mine it is "HS"). Some experiment may be needed.
When you have found the setting you need, press the buttons on the right to move the hands forward or backward until the correct time is indicated.
When you finished, press the mode button until the normal timekeeping mode returned.
Posted on Jul 24, 2011
SOURCE: my signa E377 R/F watch wont reset to correct time.It,s 42 mins fast.I need instructions.Can anybody help?
Check you have the battery in the correct way and it is the right voltage/one for your watch
Posted on Apr 26, 2012
E377
i would set a saved search on ebay, for that watch or watch parts, and have the daily email checked, that way when one comes available you will know. that's the cheapest way I can tell ya
May 08, 2014 | Watches
Alarm Chrono manual
Try link below by using the module nbr found on the back cover(4 digit nbr in a frame).
Timepieces Watches Manuals CASIO
Jan 06, 2014 | Casio G-Shock GW500A-1V Wrist Watch
Lost the manual
Try link below by using the module nbr found on the back cover (4 digit nbr in a frame).
Jan 02, 2014 | Casio G-Shock GW500A-1V Wrist Watch
My signa E377 R/F watch wont reset to correct time.It,s 42 mins fast.I need instructions.Can anybody help?
Apr 24, 2012 | Watches
Looking for Instruction Manual E377/E378 R/F Watch Having replaced Battery the LCD shows the correct time, date and month. But the pointers are 1hr8minutes fast
Jul 24, 2011 | Watches
I got water damage in my watch and need the quickest way to fix it please
Step 1 - Minimize the Moisture If your watch is exposed to moisture or falls into water, the first thing you want to do is move it to a dry location. Dry off the water on the outside of the watch with a soft rag. The glass on the front can be easily scratched, so be sure to use a soft cloth to wipe clean.
Step 2 - Remove the Cover Open the cover on the back of the watch very carefully. Often a small flathead screwdriver will help in turning the cover. Pour any water out that remains. Be careful not to touch any of the gears or parts of the watch as the watch may become irreparable.
Step 3 - Air Dry Lay the watch face down in a warm room to allow it to air dry for at least 24 hours. After replacing the cover, the watch will often return to normal use. However, it is still recommended to have the watch repaired by a professional watch repair shop. They will be able to seal the front and back properly to assure no future leaks. Have them run a pressure test to ensure there are no potential leak areas.
Standard Upkeep Proper maintenance is imperative, especially on delicate mechanisms like timepieces. Even before your watch fills with moisture or stops working, it is a good idea to maintain it on a regular basis. The inside of a watch is filled with tiny gears and sensitive parts that must be installed perfectly to work properly. Under normal use and regular maintenance, a good watch will work for a lifetime.
It is important to minimize wear and tear when possible. Even though you may not see a crack in the seal, there very well may be one that could ruin your timepiece. Water, especially salt water, can be very damaging to a watch. Find a reputable repair shop to recommend a maintenance schedule for your timepiece.
Read more: http://www.doityourself.com/stry/how-to-repair-a-watch-with-water-damage#ixzz0x91faKz5 Step 1 - Minimize the Moisture If your watch is exposed to moisture or falls into water, the first thing you want to do is move it to a dry location. Dry off the water on the outside of the watch with a soft rag. The glass on the front can be easily scratched, so be sure to use a soft cloth to wipe clean.
Aug 19, 2010 | Watches
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
I HAVE AN E377 RF WATCH THAT HAS DEVELOPED A PROBLEM. THE DIGITAL DISPLAY OF THE TIME IS SHOWING CORRECTLY BUT THE HANDS ARE SLOW BY 2HRS 20MINS. ACCORDING TO THE JEWELLER, THE BATTERY HAS PLENTY OF...
Ed.
May 02, 2009 | Watches
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
