Question about Yard Machines Red Edger
How to adjust belt on an mtd edger
I need to make an adjustment on my belt for a MTD edger. I do not see an adjustment screw anywhere. Please help. Thank you.
2 Suggested Answers
vincob
  • 718 Answers
SOURCE: I have a MTD yard man edger model 253 986 000 and
It's either a 4 or 6 inch blade go to your local home center and they will hook you up bro. Good Luck! Don't forget the thumbs.
Posted on Aug 14, 2010
My MYD edger breaks off the adjustment rod any fixes
I've broken two of them. I had a lot of vibration, and the blade was bent. I'm replacing the rod and the blade to hopefully fix the problem. If it breaks again, and I still have the vibration, I'll look at replacing the belt and possibly the pulleys.
Feb 10, 2013 | Mtd Garden
Mtd ridingmomower replace motion belt will not start now
my guess is while doing the belt you knocked the safety switch out of adjustment
Jul 08, 2012 | Mtd Garden
My mtd yard machine riding mower wont stop. it also goes when the parking brake is on, What should i look for?
belts may need replacedd, make sure all belt guides are in place, may have to adjust brake linkage
Sep 04, 2011 | Mtd Garden
Mtd 19 In. 173 CC OHV 3-In-1 self propelled. Drive will not engage. Appears as if the belt is too loose even when the drive control bar is depressed all the way. Is this adjustable? This mower hasn't...
Between the handle and the connection to the drive system, look for adjustment screw or nut and screw on cable. Maybe even check the spring tension, if handle is spring loaded and the spring is stretched it will not engage drive system. If no adjustment to be found then you must get new belt. Good Luck...
Jul 19, 2011 | Mtd 19 In. 173 CC OHV 3-In-1
Adjusting mtd carb. i there a set turns for the adjustment screws
Basic screw adjustments to start with are 3/4 of a turn from the farthest "in" setting. Don't tighten down on the screws too hard, turn down just enough intil they stop, then turn out from there. After engine starts, you can fine tune the idle speed and then the high speed crews.
Feb 18, 2010 | Mtd Products Yard Machines 158CC Tiller
Part
Your part number for the belt is: MTD 954-04032B
You can get a belt fairly cheap by going to this link: http://www.jackssmallengines.com/searchdb_more_info.cfm?part_num=265252&format=searchdb
Feb 10, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
How do I know if installed the v-belt properly for an MTD 22" self-propelled mower #12b-264c062. The belt has been installed around the engine and transmission pulleys and behind the belt keeper. does...
You need to check the owners manual. And be sure you have the correct belt.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Jul 31, 2009 | Arnold Corporation Arnold/MTD 22" Lawn...
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Installing blade belt
you have to raise the mower then drop the rear of the deck by removing the 2 pins on the blade adjustment lever.once you do that it should go pretty easy
May 17, 2009 | Mtd Garden
Yard Machines Red Edger Logo
69 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
