My technics model sa r277 stopped playing music .when I turn it on you could hear the beat coming from inside the receiver but really really low you have to literly put your ear on the receiver to hear it its like it has no power to push the sound to the speakers plus the fan is not on what's going on can I fix this
    New Friend:
    Problem Solver:
  • 17 Answers
Fan usually kicks on at high temperatures so being your not using any increased wattage (incurring heat and excessive voltage) there's no need to run the fan... (like sitting in your car listening to the radio...without the car running or being on...no gas only electrisity being used, so engine isn't running thus no heat or need for cooling system to be on! ie: water pump, radiator & fan etc.) you could have just very well blown a fuse, but typically you would here your amp 'clip-out'...indicating overheating problem...check fuse, in not the problem (first verifying fuse is still good, 'continuity'...go to manufacture's website an see if you can download a "SERVICE MANUAL"?! this will give you more insite, troubleshooting tips and technical specifications &/or updates...good luck!
Posted on May 08, 2014
Technics sa-r277 coolant problem
it can be a sign that its getting weak. can also mean ther is not enough ventilation or if fan fitted its not working properly.
Jul 08, 2017 | Technics Televison & Video
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
Technics SA-1000 Volume Level low
Hook the speakers to the remote terminals on the back and switch the front speaker control to select the remote speakers. If you have audio, your main amp channel may have an issue....
Sep 18, 2017 | Audio Players & Recorders
I am playing Cd's and have a pair of Definitive Technology- Model BP-10 tower speakers connected to my Technics SA-DX1040 5.1 Channels Receiver and while the music is playing, all of a sudden the music...
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Dec 27, 2010 | Technics SA-DX1040 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
73 people viewed this question
 Grubhead
Grubhead
