Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower starts then stalls, stalls when throttle is raised
Little silver thing below carbeurator gets hot
  • 25 Answers
Check your oil filter and oil level. Some have an oil pressure switch that saves the engine but killing spark when oil pressure is too low. That is something near the carb, usually has 2 wires coming from it.
Posted on Jun 23, 2009
Husqvarna riding mower seems to be flooding.
rebuild the carb and change the oil a couple times
Mar 21, 2012 | Husqvarna Garden
My 21 HP diesel zero turn mower starts blowing black smoke after running at higher throttle settings and temp gauge shows engine is warm. No air restrictions. New fuel filters. smooth running when cool or...
Looks like you've got a good idea on what makes diesels smoke, so I'm sure you know that black smoke is almost always from too much fuel for the air that's going in. So it can be too much fuel or too little air. If your filters are good, the next things to check are the fuel pressure and the injectors.
I know diesels, but I don't have any specific experience with lawn mowers (kubota?). Since it stalls eventually, it sounds like it's not a single cylinder (although not for sure) so I'd check injector pump first.
Sep 28, 2009 | Garden
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
It idles fine. When I press the throttle, it bogs down and stalls. I replaced the spark plug when this initially occurred.
The problem is that your carbeurator is gummed up. Get a can of carbeurator cleaner spray at any auto parts store. remove the air filter and put two squirts of cleaner into the air port hole. start it up. with the assistance of a helper, run it and squirt one squirt of cleaner at a time into the air hole until it no longer bogs down.
Aug 12, 2009 | Mantis Tiller
Engine won't start . Pour gas in cylinder it starts then quits.
hi lou. your carbeurator is gummed up. It will need to be removed, soaked in carb cleaner for three hours and then rebuilt using the correct kit.
if you are not familiar with how to do this i recommend that u have it done by a lawn mower pro
May 28, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
My Mower won't start for more than 8 sec. I changed the spark plug, gas, oil, etc. I cleaned it inside and out including the carb. left in rain for 5 min accedentaly, cleaned, na da. Help. Thanks Craftsman...
the problem is that your carbeurator is gummed from from sitting idle all winter with gas in it. Get an aerosol can of carbeurator cleaner, remove the air filter and give the air intake two squirts of carb. cleaner. Then start the mower. When it stalls again let it sit for an hour while the carbeurator cleaner works at dissolving some of that gum. Repeat the process until the mower runs again. Sometimes there is so much junk in the carb. that you have to remove it and soak it in cleaner for about three hours, and then rebuild the carb. with the proper little kit. hopefully you won't have to take this step.
Next fall let the mower run out of gas and stall then you won't have the gum in the carbeurator in the spring.
May 23, 2009 | Garden
Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Wont start
Apr 04, 2009 | Toro Lawn Mower With Toro Power Tools
Stalling Briggs & Stratton engine
carbeurator needs torn apart..cleaned and reset.
Sep 01, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
335 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
