Question about Welding Tools
Ow repair and assemble a bernzomatic st200 micro. torch
Flame is uncontrollable only works right I turn it off but then goes off because its switched to off. Torch was taken apart by a frriend n I never see how it was to begin with
4 Suggested Answers
  • 10865 Answers
SOURCE: The Blazer micro torch does not ignite (no hissing
Hi. Get a piece of very fine wire, hardware store is a good source, and run it into the nozzle. Chances are that the nozzle is clogged. Once it is hissing again it will ignite unless you also need a new flint. J.
Posted on Jul 08, 2010
SOURCE: WE HAVE A BERNZOMATIC ST200
with the solder tip attached push upward on the little black knob on the tip, its spring loaded and on one side reveals a small little chamber where you can see a small flame once you turn the gas on and apply a spark/match to the little opening. keep the knob still pushed up all this time. let the fire inside keep going, if you let the knob down and the window to the chamber closes before it gets hot enough the iron wont work but if you wait for a bit with the fire inside, then right below the tip you'll start to see that area glow red, once its glowing red your good to go, you can close the chamber and the catalyst will "burn" the gas in the area and make heat instead of the fire heating the tip. once you close the chamber you're holding open with your thunmb then the fire goes out, if its hot enough you're set to go, otherwise rinse repeat.
Posted on Nov 01, 2010
  • 78 Answers
SOURCE: Blazer pocket micro torch will
try to open up the part where the spark would come from. there should be a screw on the bottom or top to open it. This is where the flint would be.
The flint is probably worn down or it broke (you can buy new flints at pretty much any convince store around they are i believe $1-2 for 5 of them.
replace the flint and you will have a spark.
Posted on May 03, 2011
How do i clean torch? thank you for any help
Ginoni Milan Serum If you use a curling iron or other heat tool on your hair, be sure that the products you use for cleaning, conditioning and styling your hair are heat-activated. Heated hair appliances used on a daily basis can damage your hair, if you don't take the proper precautions. Heat-activated products can provide your hair with extra moisture, and help to reverse the damage caused by high temperatures. If you plan to head out right after work, it is easy to get a fresh look by dusting some matte powder on oilier areas with a big brush. Make sure that you take care of your cheeks, as this is where a lot of oil will fester.
Read More >>>> http://www.wecareskincare.com/ginoni-milan
Dec 28, 2015 | BernzOmatic Micro Pencil Torch Kit 019132
I have a small pencil torch its not flaming right.not torching just a flame
Too much gas! Turn it down and check that nothing is blocking the airways.
Mar 23, 2015 | Blazer Pencil Micro Torch PT 4000
Micro torch Mag Torch MT780 Need a assemble and disassemble guide for it. Or parts guide something to repair it. Please!
go on line and input the model number and name for this should bring up a PDF file for it
Jan 22, 2015 | Welding Tools
How to repair and assemble ST200 - Micro Torch bernzomatic
get the Bernszomatic guide it shows assembly.
ask them. its free, they dont want you to blow up, so is FREE.
id trash it. and start over.
but i use mine like that to test engines. just a valve and neck.
May 08, 2014 | Cars & Trucks
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Torch doesn't have correct flame
Without knowing the specific torch tip you're working with and what you're welding/soldering the only thing any one can suggest is cleaning the tip. You can get welding tip cleaning files any where that sells welding supplies.
Dec 23, 2013 | BernzOmatic Welding Tools
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
WE HAVE A BERNZOMATIC ST200 MICRO TORCH AND MY HUSBAND IS TRYING TO SAUDER HIS GUITAR HE CAN'T SEEM TO GET IT HOT ENOUGH TO MELT THE SAUDER. THIS IS ONE THAT IS A TORCH SAUDER COMBO THING. IS THERE A...
Oct 30, 2010 | Garden
We have a problem with the starter. Once we start
Bernzomatic Heater will not light. Full tank, but not flame; however, I can hear the igniter trying to work.Could there be spider webs present? Where do I look to find them?
Jul 09, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Welding Tools Logo
630 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
