Question about Panasonic KV Office Equipment & Supplies
Black line on scanned document - KV Panasonic Office Equipment & Supplies
EPIJAB
  • 89 Answers
SOURCE: black lines
Not sure what you have tried but if there are no lines when printing but there when scanning there is something on the scanner. Could be something as small a single dot of dirt and it will put a line down the whole page. Try cleaning the glass.
Posted on Dec 14, 2007
  • 9 Answers
SOURCE: Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Posted on Feb 17, 2008
SOURCE: Black line vertically on scanned/printed documents
This problem can be caused by a number of different issues. If it occurs when you copy, check the scanning glass to see if there is any dust/gunk on the scanner glass. Also if you machine has a document feeder than you need to check the **** glass that the paper feeds past.
If it occurs when you print than you probably need to clean your printer. Check your manual for exact details on how to clean your printer but in general it could be on a paper feed roller or it maybe something on the drum. If you let me know what printer this is happening on I can direct you to a manual if needed.
Henry
Posted on Apr 22, 2008
Nitrotrike
  • 589 Answers
SOURCE: black line scanning on digital sender
Yes. There will be an access cover / lid where the document goes in.
Open the cover, and you will see a thin glass, called the 'scan glass'.
Look in the middle of the glass. You will most likely find a glob of white-out, or ink on it.
Use rubbing alcohol to clean off the culprit.
Welcome to scanner / fax / copier troubleshooting 101!
Posted on Jun 18, 2008
SOURCE: Black lines through documents
When printing from the printer we have 2 black lines. It prints fine from the computer. How do I get the black lines to go away?
Posted on Sep 28, 2008
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
I have kodak i2600 scanner, when i was scanned document its getting black lines on the document how to solve this problem please help me
Black lines on most any scanner will be caused by dirt in the scanning system, or by a damaged/defective scanner sensor. You can clean the window.
Jul 15, 2015 | Kodak i2600 - Document scanner - 8.5 in x...
BLACK LINE THROUGH SCANNED DOCUMENTS
HI, WHERE THE BLACK LINE HAPPEND ? ADF OR BOOK PLATFORM ? IF THE ADF , YOU SHOULD CLEAN THE GALSS WHERE LEFT BY THE BOOK PLATFORM , SOMETHING IN IT TO KEEP OUT THE LIGHT. HOPE CAN HELP YOU.
Mar 10, 2014 | Canon MF8050Cn AllInOne Laser Printer
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
Jul 19, 2012 | Kodak i660 Scanner
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
Black lines
Dec 13, 2007 | Office Equipment & Supplies
32 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
