Question about Kodak EasyShare C713 Digital Camera
LCD screen No matter what time of day, the LCD screen is always dark and I cannot see the subject
I down loaded the manual.
Posted on Jun 23, 2009
I have a samsung 1080 full hd 38" flat screen tv,
I think the backlight is failing, you will need to have it replaced. It is also possible that the backlight inverter (power supply) may be faulty but that usually shows up a fault. I think it unlikely that the screen itself has failed unless it has been subjected to pressure damage.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Samsung LE40B650T2 40 in. Full HD Crystal...
Tip
Bad pictures on my Digital Camera
A digital camera is a wonderful device - it's just not as good as the human eye yet.
Some things to watch out for:
Spots in the picture - Shiny surfaces reflect your flash back to you.
Picture is dark - Bright Window behind your subject - . Use backlight setting.
Bad focus - Subject is not in the middle of the picture. (Use focus lock if you have it)
Colours don't look right - Sunlight in a building with overhead fluorescents.The camera does not know to use the fluorescent light setting. Set it.
Picture is clear but dark on an overcast day - sport setting is ON or the ISO is too fast. Use auto, 100 or 200.
Flash won't flash and subject comes out dark - light behind subject. Set the flash to 'Always' for this picture.
Do's and Don'ts
Don't drop the camera. USE the hand/neck strap.
Don't store pictures on your memory stick - make copies as soon as you can.
Don't make changes to pictures with your computer while they are on the memory stick. Work with copies on your computer.
Do not allow rain to land on the camera - rain easily runs inside.
If you use rechargable batteries - have two or more sets. Use one set until they are used up, then switch. Charge the low battery only. This maximizes the battery life and provides the longest operating time.
Clean the battery contacts in the camera two or three times a year with 99% pure alcohol and a cotton swab. It does not hurt to clean the ends of rechargeable batteries at the same time. Don't touch batteries on their ends.
on Mar 29, 2010 | Cameras
Reddish w/ horizontal lines on pictures when review on its LCD.
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall.Contact Kodak support this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
Jul 13, 2010 | Kodak EasyShare MD853 Digital Camera
My monitor plugs in blue power button blinks why ?
There is probably a failure of part of the power supply pcb. If the light blinks and the screen is totally dark, this is the likely cause. The usual culprit is decective capacitors on the pcb. See other posts on this subject here. This failure may be intermittant; in other words, it may not always occur.
Jun 02, 2010 | Samsung SyncMaster 204BW LCD Monitor
LCD screen of the camera
Turn on the flash by pressing the ok button!
Dec 03, 2009 | Genius G-Shot D613 Digital Camera
Why do pictures taken with my digital cameras nearly always look too dark when viewed through my computer although they look fine on the cameras screen
It's usually just a matter of calibration between your camera's LCD and your computer monitor. The default settings on your camera's screen should be pretty close to accurate. Your monitor could be lighter or darker, depending on many factors, such as your preferences, or out-of-the-box settings. The best bet is to adjust your computer monitor to closeley match your camera's LCD.
Jul 12, 2008 | Cameras
Dark vertical lines on tv screen
looks like lcd panel is off.the cost is abit less of anew tv!
Jul 07, 2008 | Televison & Video
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Light and dark?
The video invertor board needs replacing.
Jun 25, 2007 | Samsung LTN1785W 17 in. HDTV-Ready LCD...
LCD monitor very dark.
The fault may lie with the ccfl inverter which basically provides a high voltage to drive backlighting for the lcd display. Not sure where you can get this part other than Sharp, but look round on the internet on this subject. I successfully repaired a similar problem with a portable dvd player using a ccfl inverter normally used to modify pc base units with neon-type tubes. Cheaply available at Maplin electronics,but may be a bit large to fit inside the monitor? Could be fitted outside as the wiring is quite long enough?
Jun 10, 2007 | Sharp LL T17A3-B 17" LCD Monitor
Kodak EasyShare C713 Digital Camera Logo
82 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
