Question about 1998 Dodge Ram 2500 Truck 4WD Front Wheel Bearing & Hub Assembly fo
I Have a 5.9l 360 v8 that just recently spun a bearing or 2.
The crank is not that bad (mainly the middle is a bit rough) and the top side of the rods are fine but the caps are scored. Is it ok if i just sand down the crank with some emery cloth and put in new caps and bearings?
  • 94 Answers
Get some plastigauge at the auto store and measure the bearing to shaft clearance. You may need an oversize bearing if there is extended wear.
Posted on May 08, 2014
    Sergeant:
  • 215 Answers
You need to find out why the bearings failed in the first place before you even start to repair the crank, we do 'super finishing' on a crank grinding machine here in NZ, these are normally only owned by engine reconditioning shops. make sure the crank is running true in a set of vee blocks, or a lathe, use a runout DTI gauge to check for this.
Posted on Jun 20, 2014
What is the deep internal knock coming from moter on 2002 dodge durango v8
deep lower engine knock can possible be whats called rod knock --where damage to a piston rod either spun bearing ,wrist pin,crack bent causing it to slap on crank or piston cylinder
May 04, 2017 | Dodge Cars & Trucks
Fit new main bearings with out removing motor
Not easy to get away with the crank get hot and most of the time
get marked or hot spots replacing bearing maybe a short time fix
ive done it .take emery. Cloth and shine the crank up as much as you can .if bearing spun forget it replace crank .good luck
Feb 14, 2015 | Cars & Trucks
Bearing oil clearance and new size bearing
Is the shaft a perfect shape, if a bit out, it will fail straight away as the hardened coating is now missing. Use Engineers Blue and check the shaft.
Mar 01, 2017 | 1994 Acura Legend
No the oil clearance is correct for BOTH bearings @ .022 -.046 mm to try to get a true clearance measurement use a micrometer and measure in 4 places 90 degrees part this will check for out of round journal and compare to a factory journal size. there may be a .001 thousand or .002 thousand undersize bearing insert that will bring oil clearance in to specs. but most connecting rods get black from a spun bearing and they need to stay round so a inside micrometer is used to check that 10 times out 10 the connecting rod is replaced.
Apr 17, 2014 | 1994 Acura Legend
Crankshaft rod bearings
NO , YOU NEED A NEW CRANKSHAFT AND MAIN BEARINGS AND ROD BEARINGS
Nov 15, 2013 | Honda Civic Cars & Trucks
Spun bearing
You are up for an engine rebuild. Remove the engine and turn up side down in a stand. Remove the sump and find the failed bearing by taking off the big end caps. If you find a con rod damaged you will have to remove the head and that piston and replace the con rod. If it is a main bearing that has spun you should only have to replace the crank shaft and fit new bearing shells Either way you will need another crank shaft. Check the price of a low mileage engine from a wrecker as it will be quicker and possible cheaper in the long run
Jun 21, 2013 | Mitsubishi 3000GT Cars & Trucks
How to change rod and main bearings in 79 305
engine should be removed ,but can be done in frame.pan must be removed,loosen all main caps, remove one a a time .upper bearing half can be popped out with a small punch pushing against the bearing half,from the opposite side from the lock tab. oil crank side surface,and reinstall.rods the same way, crank the engine to get them to bottom. good luck
Apr 07, 2013 | 1977-1979 Chevy Pickup C/K Series Radiator...
Oil flow diagram: plugged galley?
you have spun a crank bearing. oil goes from pump to main bearings,rod bearings then to cam and valve train.
Aug 01, 2012 | Cars & Trucks
2002 Mazda Protege 5 knocking engine
Uhh there are no rods in the head. That dealer has a loose rod in his head maybe.
The crank, rods and pistons are all in the bottom end of the engine.
What it likely is is either a broken piston skirt or a spun rod bearing.
Spun crank bearings are rare and sound deep.
A spun rod bearing can be fairly quiet on idle depending how bad it is worn out, but it will be really loud on acceleration. Piston slap from a broken skirt can be pretty loud too but it mostly sounds like diesel rattle only a bit less. Some have described it as a loud pinging sound like detonation.
Drain the oil and check for metal debri. If you can tilt the vehicle a bit for the oil to drain more towards the drain hole that could help. Then look for metal pieces and judge their size. There should be NO glitter whatsoever in engine oil, or any kind of debri. Now a rear end or transmission is different. Those always have a little metalic sheen to them.
Best of luck.
Apr 01, 2010 | 1986 Mazda 626 Coupe
I have a spun rod bearing, and a scored crank
Talk to an engine rebuild shop near you. They should be able to save your crank if it's not broken, and get you a set of bearings and piston or anything else you need. They'll be in the Yellow pages.
Jul 04, 2009 | 1999 Oldsmobile Intrigue
1998 Dodge Ram 2500 Truck 4WD Front Wheel Bearing & Hub Assembly fo Logo
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
