Why the right channel of my tape deck has low output?
  • 88 Answers
Get some rubbing alcohol on a Q-tip and clean the playing head. It's the square metal device that pushes against the tape. That should clear it up.
Posted on May 08, 2014
Testimonial: "Well, that was what I did in the first place, still the left speaker seems to have more output compared to the right. Can be felt clearly when using the "balance" knob to cut off/listen to either channel. It happens only when I listen to my tape deck. No problems with either the stereo tuner or DVD player where the sound seems to come from both the speakers as it should."
  • Arup Dutta
    Arup Dutta May 10, 2014
  • Arup Dutta
    By the way, tape deck model is DENON DRW-750, amplifier Harman/Kardon KH6100, just letting you know if it's any help.
How do you connect tape deck to pmp 4000
Hi, use the RCA/Phono connections for the Tape In & Out. The level will be set by the Master/Main fader. If that is not so convenient (& assuming it's a PMP4000?) there should be a "Main 2" output & connections with the level controlled separately to Main 1 via a Knob / Rotary control over to the right above the "Mono" fader... Hope that helps... Good Luck!
Jul 11, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
Why the right channel output in my tape deck is low?
nostalgic!!..Really posted on 2014?..anyway clean or replace your tape deck's "HEAD".
May 08, 2014 | Televison & Video
Teac c-3rx low output
This is a fine deck and I fix them all the time. The tape heads need to be cleaned and then make sure you have the setting set right on the switches to the right. If you need help contact a service Technician.
I am in the Chicago area.
Mar 10, 2014 | Tascam Audio Players & Recorders
Technics amp to tape deck connections.
Red for Right channel (play). White for Left Channel (play). Yellow for right (Record) Black left (record). The leads should run from tape (out) play to amp in play. Same for the left channel.
Record from tape (in) to Amp (out).
Jan 29, 2014 | Audio Players & Recorders
How do I connect a teac ax-20 mixdown panel to a teac a-3340s reel to reel?
It's a 4-in, 2-out panel. Well, you attach up to 4 INPUT channels (labeled plainly on it) and run the two output channels to any two of the the Record In connectors on the Tape Deck.
Sep 11, 2011 | Teac Audio Players & Recorders
When I recorded a cassette, the problem is the stereo is going to mono either left or right channel, and also have low volume problem during recording.
This sounds like an recording pre-amp problem. Anything common to both channels problem faults are always connected with a device that has both channels going in and out of it. In this case I suspect a recording pre-amp IC.
Jul 07, 2010 | JVC TD-W254 Single Cassette Deck
LOW SOUND OUTPUT ON MY REEL TO REEL, SOMETIMES ON ONE SPEAKER ONLY..
Let me guess - the LEFT channel.
If it's a 4-head deck, the Forward tracks are arranged across the physical tape surface, front-to-back as follows:
BACK
Side 2 Left
Side 1 Right
Side 2 Right
Side 1 Left
FRONT
As you can see, the Left channel is close to the edge of the tape where most tape and head wear occur. High frequencies are affected first.
If you examine the edge of the tape when it is stationary there should be no waviness as this would cause poor head-to-tape contact.
Shine a high-intensity light on the tape where is passes over the heads. You should be able to identify the tracks. Looking closely you might also notice a worn pathway across the heads caused by miles of tape over the years. It changes the contour of the heads and how the tape rides on them. Wear can look like shiny bars (perpendicular to the tape travel) with rounded or wavy edges (not ruler straight).
Or it could just be dirty heads and transport.
Mar 09, 2010 | Audio Players & Recorders
Quiet right channel when playing pre-recorded tape.
With the deck in play mode put your finger on the imput of the channel that is low. If it buzzers the same as the other then you may have a faulty head. If it does not there is something wrong in the amp stages of the deck. You can also reverse the leads from the head and if the sound goes down on the other channel it is the head. Try doing it where the leads join with the PC Board, it will be less messing than at the head itself.
Jan 28, 2009 | Audio Players & Recorders
Sony tape decks model tc-355
Follow the left channel lead to where it joins with the PCB. Use a pointed tool and prod connections if you get a buzz then that stage in the amp is working. I suspect you will find it leads to a IC that might cause the fault. If you find it buzzers on the right but not left, then it's gone. PS don't short pins. If you can get hold of a signal injector it will make things easy.
Be careful and good luck.
Jan 08, 2009 | Sony TC-WE305 Single Cassette Deck
Nakamichi CR-4 Only Recording on One Channel...need help!
Hmmm.....heres a really stupid question but........is the head clean ? There may be a bit of oxide shorting the one side of the head out. Try cleaning the head with a q-tip and some 99% pure isopropyl alcohol. If you have done that ( you seem to be more knowledgeable than most ), I would suspect either the circuit that drives the right channel record head, or the head itself. Is the head running flat against the tape?. Is there a record/play relay or record relay somewhere in the circuit ?. I think at this point you really need a schematic. Do you have the AC oscillator signal ( bias ) present on the right record head ?. I would try this first, then look into a manual.......Good luck...Rob
May 02, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
