Question about Home
Windows fixya I have a garage door window that got broken yesterday. Do I need to have a piece custom made? Are there windows that small in the world that I can just go buy? bryanflake1984| http://www.pnrscreens.ca
  • 2,509 Answers
You may be able to get a replacement from manufacturer if the door is manufactured, however if the door is a specific one-off, measure the glass exactly or the hole, allowing 2 to 3mm less than the hole size. Make sure you measure the width top and bottom and the height right and left just in case it isn't 'square' and get a piece of safety glass cut to size at a glass merchant,. alternatively just board it up with plywood since if it's so small then maybe the light coming through isn't important?
Posted on May 08, 2014
  • 94 Answers
Go to your local Lowe's store with the size measurements of the window. they will cut you the size you need. Probably better to replace it with a plastic window. it's as clear as glass and will not shatter.
Power windows
You have to replace the broken Window Regulator
The entire cable assy & broken item
Aug 22, 2013 | 2004 Dodge Dakota
My 2008 Chevy Equinox driver side window quit working, the motor is working, all other 3 windows are working, what could be the problem.
I have an 05 equinox had same problem with driver window,ended up finding broken wires in rubber boot between door and jamb,pieced out broken wires,problem solved....
Mar 20, 2011 | 2005 Chevrolet Equinox
Front windows on 2006 Jeep grand Cherokee have come off track. Any fixes?
Remove door panels inspect for broken parts laying in bottom of door.Somtimes because of ice they can pop off track.If this is the case just put back in track and your good.If there are any broken pieces in door you will need to replace broken parts before windows will work.
Feb 09, 2011 | 2006 Jeep Grand Cherokee
Broken window pane in my Chamberlain garage door. How do I replace it?
Chamberlain doesn't make garage doors. There is usually a tag on the door itself with the name of the manufacturer.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cannot roll up drivers window. When attempted, clicking noise occurs. Took off panel and cover to see rpoblem better and removed small brown piece. I does not affect other 3 windows when removed.
Sounds like the guide that is inside the door that connects to the glass is broken. Probibly need to buy a window regulator, sometimes they come as the whole setup when you order them from the dealer
Dec 03, 2009 | 1996 Ford Contour
Windows wont work door locks go up and down when i press button for windows help please
sounds like your wiring is wrong. I would get someone to properly wire your doors.
Jun 03, 2009 | 2000 Daewoo Nubira
RH door mirror assembly
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. Then you can access the mirror assembly.. it's a huge pain to change such a small part
Mar 01, 2009 | 2002 Nissan Xterra
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Home Logo
98 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
