Question about Lexmark C748de - Printer - Color - Laser
C748de printing smudges
Black smudges on edges of pages
5 Suggested Answers
  • 2072 Answers
SOURCE: Paper has black marks only on the edge
There are several issues that will cause a problem like that.
1, As X box mentioned is a problem with the drum. That is part of what is called the print cartridge or imaging unit. There is most likely a shutter or opening in the cartridge which you can shine a flash light at and see if the defect is visible. If so you will have to replace that cartridge. I would suspect that is the most likely issue.
2. There may be something in the paper path. A small piece of paper riped off in it, something else, a piece of tape, label, etc may have made it into the machine, that will make contact with the paper and smear the image.
3. Lastly, your fuser roller may be bad causing the reprint.
How to determine where the issue is, shut the machine off while it is printing and jam the paper in the image area. See if the defect is on the paper before the fuser. Eliminates the fuser ....
Posted on Feb 19, 2008
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
SOURCE: Pringed Pages are coming out with yellow and blue smudges on edge
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Posted on Jun 18, 2009
  • 1684 Answers
SOURCE: The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
Posted on Jun 19, 2009
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Why does my lexmark C748de have no black, only cyan, magenta and yellow on prints?
Check to make sure that the black cartidge has enough black toner level, ie not empty.
Jun 23, 2014 | Lexmark C748de - Printer - Color - Laser
Jun 04, 2009 | Lexmark E232 Laser Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
Black smudge on side of paper when printing quanities
Hey, Pleas check Black imagine unit,if needed change it.
Jan 07, 2009 | Konica Minolta Magicolor 5450 Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Lexmark C748de - Printer - Color - Laser Logo
94 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
