Question about Alessi MG32 Cordless Electric Kettle
Where to buy a replacement switch for alessi mg32 kettle
jerryg50
  • 1689 Answers
SOURCE: Alessi Electric kettle
The switch is most likely defective and has to be changed. It is also possible that the heating element is pulling too much current and also has to be changed.
An appliance service tech would have the tools to test the kettle and determine the exact fault.
Jerry G.
Posted on Apr 29, 2008
  • 351 Answers
SOURCE: Where can I buy spare parts for the Alessi 9093 cordless kettle?
This site seems t0o have the parts yo are looking for ..
Alessi 9093
http://themagazine.info/products/-/167.html
Posted on May 11, 2010
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
  • 25 Answers
SOURCE: where can I get a new filter disc for my alessi bird kettle
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
Posted on Jan 16, 2011
drifterK
  • 4924 Answers
SOURCE: the handle fell off the kettle, how can I re-fix it?
If it do not have any obvious way to fix it (locking clips or screws) and it was just inserted on the metal part ..than you can use some kind of glue for plastic and fix it back again .a super -glue will work or a strong plastic adhesive .Clean both ends so that any grease to be removed...and apply the adhesive on the plastic end .. and than insert it to the metal end ..in such a way that the adhesive to fill the space and the excess substance will drain off when you press them together. leave them to react for a while without touching them ..be sure you choose a temperature resistant adhesive ...
Posted on Nov 17, 2011
Can I get element replacement
According to their website and the parts available no. Write to their customer service and protest that you don't want to discard a perfectly good kettle because the element has gone. These days kettles are classed as a throw-away item.
MG32 Electrical appliances Alessi
Nov 04, 2015 | Alessi MG32 Cordless Electric Kettle
Removal of triangular headed screws
Appliances like these are not designed to be opened. If it is faulty it should be replaced by a new one.
Jun 21, 2014 | Alessi MG32 Cordless Electric Kettle
Fix bad contact on oster electric kettle base
Replace the contact assembly. Call the manufacture about how to purchase their parts. I would also replace the one on the tank at the same time since they work together.
Apr 29, 2012 | Alessi MG32 Cordless Electric Kettle
It blew my fuse box, i have changed the fuse the light comes on but it is not heating up approx 5 years old
This happened to my Alessi kettle also. I changed the fuse in the plug but the kettle is dead! Red lights are on but the heating element in gone. From what i can gather parts are not available to fix it.
Feb 15, 2011 | Alessi MG32 Cordless Electric Kettle
What is the best way to clean this kettle - particularly the rim in the top where the limescale has built up and the resin base
Dec 06, 2010 | Alessi MG32 Cordless Electric Kettle
Flash from beneath kettle. Now not working. It is not the fuse in the plug
get it serviced the think is the heating coil may have got burnt out if you need to replace it remove the cover below and take out the coil carefully with the terminals ..now replace the coil of same wattage usually 700watts in the same way
there can also be a problem with some wire got burnt due to heating .try to find the wire located near/attached with the heating coil and check whether everything is correct
Dec 04, 2010 | Alessi MG32 Cordless Electric Kettle
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Sep 13, 2009 | Alessi MG32 Cordless Electric Kettle
Alessi MG32 Cordless Electric Kettle Logo
Top Alessi Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Are you an Alessi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
