Question about Bosch HMT8656GB Microwave Oven
Hi, we have a Bosch HMT8656GB built-in microwave, and the other night (shortly after microwaving several potatoes), it shorted out and tripped the main fuse for the kitchen sockets. We've isolated it to the microwave, but every time we plug it back in, the fuse trips immediately. Can this be repaired, or are we best off getting a new one? Thank you!
  • Joel Friedenberg May 09, 2014
    Take a look inside the unit. Posiibly you'll find a hot wire grounded. The unit has a 10 amp fuse inside I beleive, so if the unit is shorting it must be a problem before the fuse . That's if the fuse is blown. Did you check the power cord?
If the power Circuit Breaker is tripping, then it is not necessarily be the LV nor the HV circuitry that is the culprit.. It could possibly be an Earth leakage. I suggest check the Carousel Motor for Earth leakage. (also the Fan motor). The Power Fuse (in the MW) ought to blow if there is a problem with the LV or HV circuit.
Otherwise, the Inverter Board need to be repaired or replaced.
Posted on Oct 07, 2014
    Genius:
  • 1,114 Answers
Confirm that the receptacle where the microwave is plugged in is not faulty by plugging something else in the recepticle and seeing if it works or if the fuse blows. Check the power cord of the microwave for broken, frayed wires. Also check the bulb socket for broken wires. It may or may not be worth the cost of repair, depending on the repair cost verses a new microwave. There are repair parts available.
Posted on May 08, 2014
  • Amanda Hayes
    Amanda Hayes May 08, 2014
    Sorry, should have added - I've had an electrician in, and he confirms that the power point is working fine - so it's definitely the microwave! Is there an easy way to figure out what caused the short, or is there a likely culprit we could look for?
3 Suggested Answers
  • 6771 Answers
SOURCE: Hi there, I have a
This indicates one of three things, there is a short in the magnetron, or high voltage diode , or the high voltage capacitor. Now! the other possible situation is the door switch has become defective and this would apply when you first plug in the microwave oven, either way it needs to be checked and depending on parts and labor the cost could come close to a replacement.
Posted on Feb 28, 2011
ercupa190
  • 12223 Answers
SOURCE: Bosch microwave & exhaust fan trip fuse when on at the same time as the gas stove.
see the next steps: use the common sense and VOM
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Posted on Aug 01, 2012
My microwave (Bosch HMT8656GB) is not letting you shut the door properly and is not closing.
Google it on line or call them ask for tech support or go to website and see if you can download a parts manual or if they have tech support good luck
Sep 01, 2015 | Bosch Microwave Ovens
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Hi, in my home every electical applience works well. But when i switch on microwave oven the power to house will go off. MCB trips i think oven drawing more current/power. what might be the problem...
There is a dead short in side the microwave... this is causing the breaker to trip...however you should also replace the breaker to the microwave, as that should trip before the MCB...unless both are tripping at the same time...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 12, 2011 | Westinghouse WST3504 Microwave Oven
Microwave lights up and rotates but does not heat?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 07, 2011 | Bosch HMT8656GB Microwave Oven
Micro wave operating but no turntable rotation
I expect a new motor is required. Fairly inexpensive to repair.
Feb 25, 2011 | Bosch HMT8656GB Microwave Oven
Hi, we have a Bosch HMT8656GB integrated microwave (fitted in 2007) and in the last 2 weeks or so, the glass tray on the bottom of the microwave has stopped going round when the machine is in use, however,...
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Feb 04, 2011 | Bosch HMT8656GB Microwave Oven
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
When I plug the unit into the outlet, the GFI pops up
There is a short internally in the microwave somewhere... the GFCI checks and see the short and immediately trips out...
You will need to use an OHM meter and check out the circuitry to find the shorted place inside the microwave...
heatman101
Oct 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch HMT8656GB Microwave Oven Logo
243 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
