Question about Samsung GALAXY S4
How to connect Lumix LF1 camera to samsung galaxy S4 via NFC?
How to connect to a Lumix phone via NFC
torre117
  • 117 Answers
SOURCE: cannot send video via text from samsung galaxy note 2 to samsung galaxy note 1
There might be some software differences between the Note 2 and Note 1.
MIGHT be, it could also be a glitch or maybe the mobile network (3G) wasn't turned on, and as far as I know, you have to press "download" on the message you get when someone tries to send you and MMS (picture/video).
If neither of the above works, it could be a glitch, or in worst case, a software difference that makes the phone unable to see/download the MMS.
Posted on Jan 17, 2013
SOURCE: samsung galaxy s4 paywave
My friend its old news there is no this feature in s4, During the first day of the Mobile World Congress in Barcelona , Visa announced its partnership with Samsung. A mobile application called PayWave will be installed on the next generation of Samsung smartphones. PayWave work with an NFC chip and enable mobile payments.
Posted on Apr 29, 2013
F1xer
  • 415 Answers
SOURCE: I had samsung Galaxy S4,i use it for the first
Try to switch it on with the power cable in, I had a galaxy nexus and had charging problems because the cable connection to the phone was loose.
If that doesnt work then check the cable it may not be charging.
it sounds the phone is new so I think if all else fails then change it for another!
Posted on Nov 02, 2013
tammerste71410
  • 9 Answers
SOURCE: Auto Shutdown Samsung GALAXY S4
Did it start over or just died for you? I noticed that my S4 was starting over all the time although it was in my pocket and I didn't touch it. But I figured that I have some option to automatically download updates, and when it does, it restarts itself. Hope this may be a help for you?
Posted on Mar 26, 2014
vansheene
  • 309 Answers
SOURCE: i need my samsung galaxy s4 work in other country, i need free unlock code.
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
I have a Samsung galaxy tab4 and I cannot get on my play store. it keeps telling me to check my connections
it means you are not connected to the internet via a cell data plan or wifi.
Feb 15, 2016 | Samsung GALAXY S4
Is the bluetooth on Capella sleep and sound alarm clock, CR50, compatible with an Android samsung galaxy s4? I can't get it to pair
Samsung Galaxy S4: Trying to pair by Bluetooth to Capella CR50 Desk clock: Unable to pair:
Hello..
Yes, the Capella CR50 should be able to Bluetooth pair with any device that can connect via Bluetooth (as stated in the Capella product description).
If you are not able to connect try doing the following (process of elimination) to resolve why this is happening:
  • Turn off and turn on again Bluetooth mode
  • Try resetting the Bluetooth app in Applications>All Applications under Phone Settings
  • Try eliminating apps that may be affecting the bluetooth connection.. you can narrow this down by rebooting the phone into Safe Mode. If in Safe Mode, your S4 is able to connect via bluetooth to the Capella CR50, that will tell you that it is software related, and most likely an app that you installed that is not playing nice with your phone. You can either remove apps one by one and retrying to connect via bluetooth to find and eliminate the issue, or remove all the apps you installed and start fresh.
(Note: removing an app with erase any settings you set up as well as any database within the app (such as a game with scores/levels/and any rewards you received/purchased, unless that database is saved in an online cloud account you sign into specifically for that app, or sync to Facebook (FB) while having the game installed in your FB account
How to get S4 in and out of Safemode:
How To Set Up Bluetooth On Your Samsung Galaxy S4 Phones 4u
Jan 29, 2016 | Samsung Cell Phones
I can not open emails with attachments camera flash will not work cannot answer text messages that i receive
Samsung Galaxy S4 Troubleshooting - The Droid Guy
thedroidguy.com/samsung-galaxy-s4-troubleshooting
Galaxy S4 won't charge, won't turn on; Galaxy S4 camera flash not working ..... S4Can't Receive Calls; S4 Can't Open Emails; S4 Headphone Does Not work ..... Galaxy S4 won't download any email attachment; Samsung Galaxy S4 stuck at ...
Samsung Galaxy Note 4 Troubleshooting - The Droid Guy
thedroidguy.com/samsung-galaxy-note-4-troubleshooting
Samsung Galaxy Note 4 Battery Is Not Working Issue & Other Related Problems ...Galaxy Note 4 Stuck In Boot Screen, Does Not Start, Other Related Problems .....Data After Lollipop; Galaxy Note 4 LED Indicator Not Working After Lollipop ..... When Iopen an attachment from any e-mail (pdf, excel, word, note), I can not ...
Amazon.com: Customer Discussions: Kindle Fire and email attachments
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Dec 26, 2011 - Electronics. TV & Video Home Audio & Theater Camera, Photo & Video Cell Phones & Accessories .... why can't I open or view email attachments on my Kindle Fire? ... Please scroll down and tell me if the box beside Enable Flash is checked. ... Me:I can read the emails and comcast.net does not work either
Problems After Updating to iOS 9.0.1? - iPhone Topics
www.iphonetopics.com/ios-9-0-1-problems/
Jan 20, 2016 | Cell Phones
How do I change connection mode on my galaxy s4 mini with android 4.4.2?
Turn on your phones screen drop down your notification bar and press notification about your phone connected via usb and it gives you two options and one of them its Mtp and second Ftp. Choose Mtp. And thats all
Jun 25, 2014 | Samsung Security Cctv Sod-14c Soc-120...
Samsung galaxy s4 paywave
Apr 29, 2013 | Samsung Cell Phones
FREE samsung GALAXY ACE 2 unlock codes
Only certain basic model phones can be unlocked for free. A unique unlock code is required to unlock every mobile phones. And these unlock codes can be obtained either from the respective network provider or from any paid unlocking source. You must find any reliable and cost effective source for it. For example, You can get the accurate unlock code at low cost from www.simpleunlocking.com/samsung-galaxy-ace-2-i8160/rs16wp9/ with easy instructions on unlocking process. All the best mate.
Nov 18, 2012 | Samsung S5830l Galaxy Ace Black Unlocked...
Samsung GALAXY S4 Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
