Question about Motorsports
A rough idol on my 1989 corvette
I went to long without driving my 1989 corvette. And I fear that the gas may have shellacked my injectors and possibly my throttle body. Just wondering witch company makes the very best injection cleaner or any other ideas how to clean it up. Thanks.
    Problem Solver:
  • 5 Answers
I recommend against most additives. The proper way is to drain the tank. Replace the fuel filters and blow old gas out of the lines with compressed air. After reassembly, fill with good new/clean gas. Fire it up. Let the good gas run through it awhile it should clear out the effects of the bad gas. If it still stumbles remove air cleaner tube and use quick squirts of carb and choke cleaner into the throttle body. Just enough to keep it from dying. That should clean it out. Next time use a proper fuel stabilizer like Stabil for long term storage.
Posted on May 17, 2014
    Genius:
  • 1,114 Answers
Lucas , Sea foam and Royal Purple are popular brands of fuel system cleaner. You may also want to consider replaceing the fuel filter.
Posted on May 08, 2014
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Other things you might find are corrosion in the ignition system,
Lifters that are no pumped up fully because the OIL is turning to sludge with age and the lifters lost there prime while sitting,
I suggest running all the fuel out of it, flling it up with 93 octane, changing the oil, and go through the ignition system. then drive it for a good 60 miles at freeway speeds to get all the fluids moving, and everything heated up and moving to blow out the years of abuse (from sitting)
If that does not help (in my experience in the late 80's cleaning those old injectors never really helped much, they were not very good injectors) You can find cheep injectors at Injector Warehouse The Fuel Injectors You Need or at 1989 1991 CHEVROLET CORVETTE FUEL INJECTOR REPLACEMENT OE REPLACEMENT.. at a resonable cost.
Along with a Fuel additive to prevent fuel from going bad, I suggest starting it at least twice a year for 30 minutes to prevent things like this.
Worst case scenario is that it sat so long the cylinders started to rust and the engine now needs to be Ovehauled.
Posted on May 27, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
Sir how long has it been exactly? how much gas was left in the tank at the time of non-operation what grade was the fuel that was left? based off of your answers i can formulate you a product that would best suit your needs as well as prevent any further damage bad fuel may or might cause. I ascertain that the vehicle is fuel injecting sequential multi-port. and if you made it through a long drive albeit performance -hindered you have a fair chance of preventing a major job and getting your beauty back healthy with the best product you can get. please message me with the required info and ill give you a call the products that i sent to you on this answer are what i have had the best experience with based your initial info i would say to go ahead and put all of the mystery oil in gas tank and when you are finished driving for the day put the heet in and let it sit overnight or for 24 hours if you can it doesnt like to be disturbed
Posted on Dec 05, 2015
P0401 & P0171 Mazda Protege '02
It sounds like you may have an EGR valve sticking open. That can also cause the p0171 code, which means fuel system lean, and the p0401 which is insufficient EGR flow, kinda sounds like the valve may just be stuck open and not moving at all. replace the EGR valve.
Mar 05, 2012 | 2002 Mazda Protege
After motor warms up and stop in gear with the brake on it will rough idle and surge.
These vehicles are common for leaking fuel injectors. I would do an injector drop or balance test.
Nov 29, 2010 | 1989 Chevrolet Corvette
1989 corvette runs rough, wants to stall even after new plugs and rotor.
i want to give you the right answer but the only thing i think of is the mass air flow sensor.
Apr 06, 2010 | 1989 Chevrolet Corvette
Rough idle
The cam or crank sensor is going out when driving at high speeds. I would have those parts check, and have the fuel pressure check , fuel filter change to be on the safe side.
Good luck
Jul 19, 2009 | 1989 Chevrolet Corvette
1989 Corvette starting and idle problems
replace the coolant temp sensor, not the coolant temp sending unit
Jun 05, 2009 | 1989 Chevrolet Corvette
Rough idling,rough acceleration then runs decent when i back off
you may need to clean the injectors
what you can do is
you can buy some injector cleaner and see if this helps
make Shaw you get a decent brand as the cheep ones do not work as good
drive around with this in your gas tank
when you have in in your gas tank it helps clean them if you do some harsh acceleration but don't race the motor and don't speed
in other words get to the speed limit fast
this will apply pressure and will push through any gunk build up
there may be some smoke for a while from the exhaust but is will go back to normal when the fuel injector has finished cleaning and all the build up is gone
hopes this helps
Dec 28, 2008 | 1989 Mazda MPV
Started idoling rough and driving rough like spark plug off
check fuel filter then check the ignition system
Aug 02, 2008 | 1995 Nissan Maxima
Motorsports Logo
487 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
