Question about Plumbing
Pacific hydrostar parts
I have a harbor freight 1hp pump model 47906 and I need part numbers 31 immobile ring and part number 32 motor ring. HF cannot supply. Can you. Thanks
    Top Expert:
  • 45,144 Answers
Nope.
Posted on May 08, 2014
4 Suggested Answers
SOURCE: Winterizing a well pump and pressure tank
If this is the pump I am thinking of, it should drain if you disconnect the hose to the pressure tank.
The other option is to place a "T" connection on the intake to the pump, between the pump and well. Place a garden hose valve on the new branch. After you drain your system, attach a 2' hose to the new valve and place the other end into some antifreeze. Run the pump to draw some antifreeze into the unit. This will protect it from freezing and rust over the winter.
Posted on Apr 26, 2010
  • 4 Answers
SOURCE: Wher can I get a manual for a pacific hydrostar
http://manuals.harborfreight.com/manuals/2000-2999/2955.pdf
Posted on Jan 09, 2011
dogsled48195
  • 411 Answers
SOURCE: I have a pacific hydrostar vertical float sump
The Float Switch (2) automatically switches on and off at a water depth of approxi. mately 4 inches. The ON/OFF height can be manually changed by adjusting the Float Switch Lock.
Posted on Jan 28, 2011
Trying to find new batteries for Chicago tool , model #45803
Hello, Linda -
Clarification: You are seeking replacement batteries for a Chicago Electric Power Tools Cordless Circular Saw. If so . . .
Apparently new Chicago Electric Power Tools are exclusive to Harbor Freight.
I have not found specifications for your model circular saw, so I do not know what kind and what voltage a replacement battery or batteries would be. Instead, I suggest you make a telephone call to Harbor Freight Customer Service and ask about the availability of a replacement battery or replacement batteries for your cordless circular saw.
Note: Before calling Harbor Freight Customer Service, I suggest you investigate the cost of buying a new similar cordless circular saw. My experience with some cordless power tolls is that the replacement rechargeable battery was more expensive than buying a new cordless tool. (Meaning: The old cordless power tool was sent to electronics recycling, and not just tossed in the trash.)
This is the Customer Service telephone number for Harbor Freight:
800-444-3353
Monday - Saturday 5am to 8pm (Pacific Time)
Sunday 6am - 6pm (Pacific Time)
Best wishes.
Apr 10, 2018 | Air Tools & Compressors
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Hydrostar manual
they are sold @ Harbor Freight Tools, you can try there, the only other place that I can find this brand of pump is @ sears, but that is only for small 264GPM submersibles. can't seem to locate a web site for the company that makes them. you may look on the pump to see if you can locate where they are made.
Aug 18, 2014 | Plumbing
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
I have a central pneumatic 46240 air nailer. Can anyone tell me where to find a parts list for this.
Central nailers are sold thru Harbor freight. They sell parts for their current models. Easy to check. Go to their web site and try to locate your model number. If found, look at the lower part of the page for link to manual and parts list including 800 number. If your model is no longer available at harbor freight, web site, ask the manager if they have returned nailers that you can use for parts. (they get a lot of tools back) If still no joy, post again with the parts that you need, maybe I can suggest an alternative. Good luck
Aug 31, 2011 | Air Tools & Compressors
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
When air is turn on impact will only turn to the right and fluid leaks out at the left button that would reverse it but it will not reverse to the left.Do I have a O ring messed up or what?
Same problem - Valves parts 31 and 32 (Qty 2 EA) needed replaced. I called Harbor Freight 1-800-444-3353 and pressed "0" to ask a technical question after following the first set of prompts.. "Continue in English...etc"
The Item number for the TL1017 is "93100". The repair kit for the valves is SKU# 12602. The total with shipping was $9.08 for me but may be a little different by the time you are reading this reply.. Haven't received them yet, so I can't comment on the parts at this time.
Mar 19, 2011 | Campbell Hausfeld TL1017 3/8" Butterfly...
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 | Garden
Parts Diagram for TL1017
I haven't tried this yet but will when they open., depending on part price. I am going to get part numbers 31 and 32. http://manuals.harborfreight.com/manuals/93000-93999/93100.pdf
May 22, 2009 | Campbell Hausfeld TL1017 3/8" Butterfly...
Plumbing Logo
319 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
