Question about Swimways Singing Gondolier Toy
Why won't the propeller in my Singing Gondolier rotate?
Why won't the propeller on my Singing Gondolier rotate?
  • 2,509 Answers
Batteries are low or poor connection to motor or switch or motor has seized. Is it trying to turn at all?
Posted on May 08, 2014
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
When I start powerr-up 3 propellers turn in unison but one prop only starts to turn when the power is almost at full power
I youtubed your Model: X4 H107 RC
All propellers are in unison. Your model may be faulty.
All videos I have found show all 4 propellers working at all times.
Check the one propeller and see if there is anything obscuring it's rotation. Otherwise contact the store or the manufactuer.
Aug 05, 2014 | HUBSAN The X4 H107 R C Micro Quad Copter 2...
How do I get the propeller on the Singing Gondolier to rotate, is there a separate battery for it?
There should be battery's in the gondolier as well as the controller.
Usually they are the rechargeable type.
May 08, 2014 | Swimways Singing Gondolier Toy
Singing coach unlimited : lessons won't open in the program, everything else seems to work fine
Try uninstalling and Re installing but before you do that do a windows update just to make sure theres no important stuff that needs to be downloaded
May 09, 2011 | Linspire Carry A Tune Singing Coach...
I have a Hacker Gondolier record player fitted with a Garrard 2025TC record deck. The record deck suddenly made a light whining noise then stopped rotating altogether. The belt is still intact. Will the...
First check to see you can turn the motor by hand. If it is stiff there's something wrong with the motor. If OK then have a look at the motor. If it works on 12 volts or under, you can attach a 9 volt battery PP9 type to it. If it's 6 volts, use a 6 volt battery! (You might have to remove any wires going to the motor to do the test). This should cause it to spin. If it doesn't it's dead. If it does check the voltage supply to the motor. Also check for broken plastic parts anywhere on the deck.
Dec 08, 2010 | Audio Players & Recorders
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
The seal on the front axle on the passenger side is leaking.is it hard to replace myself.
here is a diagram on how to replace the front pinion seal.
please do not forget to rate and comment about your experience with fixya.
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove both half shafts.
  3. Mark propeller shaft and pinion flange for installation reference.
  4. Remove front propeller shaft.
  5. Rotate pinion gear three to four times, to verify pinion rotates smoothly.
  6. Record pinion flange rotating torque with an inch pound torque wrench for installation reference.
  7. Hold flange with Holder 6719 and four bolts and washers.
  8. Remove pinion nut.
  9. Remove flange with Remover C-452.
  10. Remove pinion seal with a pry tool.
    67189-dako-g28.gif Removing the companion flange
    67189-dako-g25.gif Measuring pinion rotating torque
    67189-dako-g27.gif Pinion seal installer
    67189-dako-g26.gif Tightening the pinion nut
To install:
  1. Apply a light coating of gear lubricant on the lip of pinion seal.
  2. Install seal with Installer C-3972-A and Handle C-4171.
  3. Install pinion flange onto the pinion with Installer C-3718 and holder.
  4. Hold pinion flange with Holder 6719A.
  5. Install new pinion nut and tighten nut until there is zero bearing end-play.
    CAUTION Do not exceed the minimum tightening torque when installing the companion flange at this point. Damage to the collapsible spacer or bearings may result.
  6. Tighten pinion nut to 271 Nm (200 ft. lbs.).
    CAUTION Never loosen pinion nut to decrease pinion bearing rotating torque and never exceed specified preload torque. If preload torque or rotating torque is exceeded a new collapsible spacer must be installed.
  7. Record pinion flange rotating torque, with a torque wrench. Rotating torque should be equal to the reading recorded during removal plus an additional 0.56 Nm (5 inch lbs.).
  8. If rotating torque is low, tighten pinion nut in 6.8 Nm (5 ft. lbs.) increments until rotating torque is achieved.
    CAUTION If maximum tightening torque is reached prior to reaching the required rotating torque, the collapsible spacer may have been damaged. Replace the collapsible spacer.
  9. Install propeller shaft with reference marks aligned.
  10. Install half shafts.
Apr 12, 2009 | 2001 Dodge Durango
Swimways Singing Gondolier Toy Logo
650 people viewed this question
Top Swimways Home Experts
john h
Tom Chichester
Are you a Swimways Home Expert? Answer questions, earn points and help others
