Looking for complete list of error codes for kenmore elite model 630.12913
SOURCE: I have an error code
Quoting another board:
Sears Kenmore Whirlpool LG 721.63683300. F-9
on this microwave IS inverter related.
There is a service tech
troubleshooting document stuffed in behind the control board cover
which has some testing procedures. My problem was the magnatron and
checked out bad with the help of this document. It would run for a few
seconds making clicks and then say F-9. It has been working great since
I replaced the magnatron PN 6324w1a002c.
f9 model 721.63764300
Kenmore
Elite 36 " over tne counter microwave is supplied by LG made by Gold
Star, made in China. It's main problem is the high voltage inverter
board supplyed by Sears Parts. If you get a F-9 code on your microwave
display screen and the micro quits it's probably this board. Reset the
machine by pulling the power plug and waiting an hour. If it is the
high voltage board is at fault it will probably fail after 45 seconds
of start up. This part is really hard to get at but is less than $100.
A qualified technician should be able to remove and repair this item in
less than hour. Some techs will quote you $300 labor, don't buy it, it
should cost a $100 or less. No need to buy another microwave.
SOURCE: kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
SOURCE: Kenmore Elite He5t Washer Error F24
If it is not the plug at the bottom is ok and the temp. sensor is ok.Check the plug on the CCU on top mine was not even plugged in. When I plugged it in the washer started working. You have to take the top off to get to it,but it is easy. Three screws on the back top and the top will slide off easily. There is a troubleshooting manual in the front bottom panel on right side of panel. Page 10 troubleshoots the temp. sensor. The book gives you all the troubleshooting codes. The front panel comes off easily by unscrewing three screws on the very bottom of the panel.
SOURCE: f2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
