Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
WHY THE PUMP WONT TURN ON,
IPUSH THE TEST BUTTON AND THE PUMP WILL NOT TURN ON, THE BATTRY IS CHARGED, IT SEEMS TO CLICK, BUT NOTHING. I CHECKED THE FLOAT, WHEN PUT IN THE UP POSITION, THE ALARM SOUNDS BUT PUMP DOESN'T WORK.
    Top Expert:
  • 45,144 Answers
It is possible that the pump itself has failed.
Posted on May 08, 2014
Phone full battery but wont turn back on
may be battry is outdated or extra fully charged thats why sometimes it react like this or the size also bigger than normal battry so try new battry or check the PIN which is connected to battry when u put battry in mobile...thank you
Nov 03, 2013 | Samsung Galaxy Pocket
Jeep wont start, engine goes to turn over but wont go all the way
Ok...what you need to determine next is if the fuel pump is operating. Turn the key to the on position and have someone listen at the tank. If you can't hear it, it's not on. (that can be pump relay, pump or sometimes asd relay) to quick check relays see if you can feel each click when the key is turned on. If you can get the pump to run by banging on the tank bottom go no further and replace the pump. Most relays are the exact same and can be interchanged as well (except abs relay)
If the pump is coming on the next item to check is the crank position sensor. You will need a digital multi-meter and a manual for the test, but if you shoot some carb cleaner into the intake and the engine starts (do while cranking) likely it is OK and then back to the pump or get a chiltons manual and a meter and do complete testing. Battery needs to be fully charged or any tests are invalid.
May 31, 2010 | 2001 Jeep Grand Cherokee
Battry keeps draing
i'd have the battery and charging system checked
Jan 24, 2010 | 1991 Chevrolet Suburban
Sony ericsson w200i wont turn on after being charged
It means that it is dry. Your phone seems to be defective. Call your phone company or take it to their phone store, and see if they can swap it out.
Mar 31, 2009 | Sony Ericsson W200i Cellular Phone
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Battery not charging
cheers for any helpBasic test on the system can be done with a $10 multi meter. You need voltage of 12.4 or so in system with battry no lights ignition off, static test. Then with motor running voltage should run up to 14.2-14.5 volts which is what mine does. Battery never goes flat. If this does not happen substitute another reg! See if there is a change. get creative and look on ebay . GBP5-10 or ask Col? heaps in Germany on 'bay Charging the easiest thing on Mito to fix. Regulator just normal Ducati type .,,,
Nov 10, 2008 | 1993 Cagiva Mito 125 - Lawson
52 inch TV wont come off Demo Mode I have original Remote
Ipushed on and off button and video button at the same time.
Jul 07, 2008 | Televison & Video
Phone wont power on
Sounds like it isn't charging properly, Try cleaning your battery contacts with rubbing alchol and a q-tip, be sure to ge the contacts on the battry & phone, also get your charging port. Good Luck
Sep 22, 2007 | Motorola Mobility RAZR V3
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
334 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
