Question about Hotpoint RVM1535 1.5 Cu. Ft. Over-the-Range Microwave Oven with Convenience Cooking Controls, Time
Where is the fuse
Looking for the fuse to replace
    Top Expert:
  • Hotpoint Master
  • 44,148 Answers
The most likely location for the fuse is inside the oven housing.
Posted on May 08, 2014
I have a short somewhere that causes all my gages to not work. What do I look for
Check the instrument cluster fuse in the fuse panel. The solution maybe as simple as replacing a bad fuse. You can buy a replace fuse at the auto parts but do not downsize or upsize the rating of the fuse. Keep the fuse rating the same as the one you are replacing.
Mar 11, 2014 | 2004 Ford Taurus
No tail lights
Check your fuse box. Look in the manual for location of fuse box and location of tail light fuse and replace fuse. You can switch a fuse of the same amps to test out brake lights first, if they work, replace the fuse you tested with and get another fuse at auto parts store. Sometimes the dealer leaves extra replacement fuses in the fuse box so look around before you buy. If that does,\'t work check your bulbs. The may both be bad. Check your wires where they meet the bulbs for corrosion or breakage. Good luck
Apr 17, 2012 | 2003 Pontiac Bonneville
Fuse
Hello!
Why do you want to replace fuse? Is your projector dead? In many cases just a fuse replacement will not solve the problem. if fuse is blown, good chance, that power supply has shorted components. still, you may try to replace the fuse with lower grade, first, and observe the behavior. If unit turns on and starts operate normally, then fuse blows, you may install the stock fuse. Means: it's just a fuse's issue. If it blows right away, don't even try to put regular fuse, instead. unit must be repaired, first. Power supply or ballast might be shorted. To locate a fuse, you must look around the unit and find a little door, says: fuse. it might have a screw or two holding it, might not. Look at the fuse, first: if it looks pulverized, don't even dare to replace it! it will blow again and make more damage to the unit. If thin wire inside is just torn, then follow the procedure, described above. If the fuse is ceramic, you won't be able to determine, how it blew. Look at the fuse's rating: it might be written on a fuse door, or on the fuse, itself. could be from 5amp to 10amp, depend on power consumption. Remember: first, install the fuse with 1/2 of value: i.e: 6amp-put 3amp first, etc. Good luck with your project.
Thanks,
Alex.
Jan 07, 2012 | Panasonic PTAE2000U LCD Projector
Power window's locks and mirrors do not work. Is there a fuse that could be replaced or a bad relay?
Yes there is a fuse that can be replaced. Find your fuse box(there may be two) in the vehicle or in the engine compartment. And look at the cover of the box, there should be a listing of what fuse belongs to what systems. Check the appropriate fuse, if blown in the middle, replace with same amp fuse.
Feb 06, 2011 | 2004 Jeep Grand Cherokee
Looking for cigarette lighter fuse location...
Look for the accessories fuse in the fuse panel. If the fuse is still good then you cigarette lighter is burnt out and will need to be replaced. Hope this will help you.
May 20, 2010 | Cars & Trucks
Replace fuse for radio
if you look in your owners manual in the glove box it will tell you where the fuse box is located and what each fuse feeds,
Jan 21, 2010 | 2002 Toyota Camry
Clock and lighter do not work. elecrtic miiors
You need to replace the fuse. Look in your owner manual under index and look for fuse box location. Remove the fuse box cover and find the fuse that states cigar lighter or mirror. Remove that fuse and replace with new 15 amp fuse. Your fuse box should have a fuse puller and auxilary fueses
Jan 06, 2010 | 2000 Toyota Camry
2002 Chevy Impala Turning Signal Lights
could be fuse or turnsignal relay, look on theb ack panel of your fuse box, which is inside the car. it should be there like a 25a fuse...the trunsignal relay is under the dash it looks loike a lil-canaster with a plug in it.....replace this if the fuse in the fuse box is good, you may also have one unde the hood in the relays/fuse boxx, it will also have a diagram of fuse locations/functions on its lid. just look close
May 19, 2009 | 2002 Chevrolet Impala
Headlights not working
Look in your owners manual for the fuse block diagram. This will show you which fuse or fuses control these lights. Open up the fuse box and replace that fuse. Some fuses look like they are still ok but they have a hairline crack in them. Sooooooo to be sure, replace the fuse in question with a new one of the same amperage. If you need fuses, or someone to show you more about this go to any autozone store and they will sell you the fuse, show you where the fuse is located and probably even replace it for you all for the cost of the fuse.
May 07, 2009 | 1994 Oldsmobile Bravada
Fuse box diagram
I hope this PDF will help.
Eitan.
Jun 04, 2008 | 1996 Ford Probe
Hotpoint RVM1535 1.5 Cu. Ft. Over-the-Range Microwave Oven with Convenience Cooking Controls, Time Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
