P98 RISO EZ200 GIVES ERROR CODE P98
We own a Risco RZ 371E , and are not able to use it, due to a code that has appeared on the screen: Code P-98---5 What does this code mean?
According to info at following link, error code P98-5 on RISO Z series is "hardware error" meaning something is wrong with a part in the machine. http://mfpdoc.com/?l=en&mod=free&chap=erc&brand=Riso&model=RZ%20Series&page=14
Link to service manual: http://mfpdoc.com/?l=en&mod=docs&brand=Riso&strSearch=RZ Series Riso RZ3 Series Service manual Parts Repair download
May 21, 2016 | Office Equipment & Supplies
P98-025 errow on rz riso 200ep
Search online for "error code 'yours' + your make & model"
Sep 02, 2015 | Office Equipment & Supplies
What can cause this error code p98-934 riso ez 200
This is an unspecified hardware error: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=EZ200&page=9
Get in touch with Risograph support at: http://us.riso.com/support
May 28, 2015 | Office Equipment & Supplies
Cz -180 Error Code P98-934
RISO CZ -180Model
Problem :- P04-513
Feb 21, 2013 | Riso RZ220 Duplicator
Error code P98 on riso
what this problem for Erorr P98 Riso RZ 230 AW
Nov 28, 2012 | Riso RZ390 Duplicator
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
Riso rz220 ui error code P02-405
Error P02-405 means: The upper-limit sensor does not go ON within 12 seconds after the elevator motor operates in the raising direction.
Jan 20, 2011 | Riso RZ220 Duplicator
jasbo
jasbo
