Question about Sharp AR-M162 All-In-One Laser Printer
Why is paper folding and jaming. print smudges when paper removed
How can I correct paper coming out
2 Suggested Answers
  • 2072 Answers
SOURCE: Paper Jammed
Remove all the cartridges and look around. There may be a small piece of paper torn off inside the machine on a sensor.
It is possible a sensor has come loose or a spring has come off of one of the actuators.
Check carefully.
Posted on Feb 16, 2008
When printing in color the right edge of paper is smuged
Inks from your printhead is deposited on right side of the soft sponge across the printhead pathway. Take a tissue paper and fold it and gently dap it dry
Nov 01, 2012 | HP PSC 1600 InkJet Printer
Samsung CLX3170 printer makes loud clanging noise when printing and smudges some lines. Started after a paper jam. Have turned off/on several times
there is a rest of the paper jamed still inside the printer you need to remove all the jamed paper then it will work, to find out where the paper stuck's open the front and rear cover, maby you have to remove the toner cardriges as well.
May 17, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam I tried to print some labels and the label paper is stuck in printer
1.When ever you place papers in the paper tray use fine papers which are not having any folds.
2.Keeps the papers correctly in the tray.
To Remove the stuck paper press the "START" button and hold it for some time. The torn paper will come out automatically. If the paper has not come out completely give the printer for service and get the paper removed completely.
Aug 31, 2009 | Office Equipment & Supplies
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Smudged image in HP 8000dn
You need a new TRANSFER ROLLER, it's the spongy roller under the drum.
Jan 16, 2009 | HP LJ-8000DN Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Sharp AR-M162 All-In-One Laser Printer Logo
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
