Question about Cameras
Instruction guide manual
PRAKTICA DPix 1027
  • 95 Answers
SOURCE: I have lost the disc
go to the link below
http://www.praktica-uk.com/dload.php
Posted on Jan 30, 2009
guru_dev
  • 315 Answers
SOURCE: lost installation disk for praktica dpix 5200
Please download the driver from this website:
Posted on Apr 27, 2009
  • 11967 Answers
SOURCE: just bought praktica dpix 810z
It means the camera has a 32mb capacity internal memory. This allows you to take pictures with no card in the camera. You won't be able to take very many pictures and most people have trouble with the internal memory once they start to use it. I recommend you don't. Instead, buy an SD memory card. The owner's manual should tell you the maximum size your camera will allow.
Posted on Oct 14, 2010
  • 11967 Answers
SOURCE: lens error 0x0211 and lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 16, 2011
ZJLimited
  • 17970 Answers
SOURCE: PRAKTICA DPIX 5200 MANUAL
Praktica Site offer your customers the use of a dedicated Digital Helpline that is available to offer advice on every aspect of your Praktica digital camera. The Helpline is staffed by operators who are fully conversant with all cameras in our digital range phone 0800 043 9070
Help and advice is available on this number from Monday to Friday between 8.30 and 17.30. Calls are charged at standard BT rate.
Email support is also available on digital@prakticasupport.co.uk
For help or assistance with driver software please call our digital helpline on 0870 060 3525.
Hope helps.
Posted on Mar 25, 2011
Manual for praktica dpix 815z camera
www.praktica.de/index.php
Jul 27, 2014 | Cameras
I lost my CD software of my praktica Camera DPix 1100Z and i cant have my photos transfered on my laptop.I need your assistance.
You can download the software from Praktica's website:
http://www.praktica.de/index.php?id=105&L=1
Just follow the instructions to download and install the software, and you should be good.
May 23, 2011 | Computers & Internet
PRAKTICA DPIX 5200 MANUAL FREE OF CHARGE
Hope helps.
Mar 25, 2011 | Cameras
Hope helps.
Did not get a disc with my dpix 5200 camera im unable to send pic
Prakticam, unhelpfully don't have anything for their cameras more than a couple of years old and don't seem to care if you mislay the disc you paid for.So be warned, don't buy Praktica. I have the 5200, you have firstly to put your usb in computer, switch on camera, switch camera to view pictures taken mode, and because it auto switches to take picture mode you then carefully attach camera end into camera whilst camera is still switched on! Then go to my computer and click on F: the pictures download. Then to save them click on first pic, hold shift key down and then click on last pic they should all highlight, right click and then hover 'send to' and send by left clicking to my documents. I remember that it took me 4 hours to work it out. Found this looking for manual to download, cannot change date now......
Apr 08, 2009 | Praktica Dpix 3000 Digital Camera
PRAKTICA DPIX5201G
First switch on camera then attach usb cable.
Computer sees it as a memory device.
Mar 03, 2009 | Praktica Dpix 3000 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
