Question about Garden
What size belt is on a Ford LGT 125 with a 42" mowing deck?
  • 148 Answers
SOURCE: need deck belt size yardman model numbera42707
I would suggest downloading the owners manual from www.managemyhome.com and it will tell you what size belt you need.
Posted on May 19, 2009
MIlfordPrint
  • 90 Answers
SOURCE: belt diagram
You can find the diagram here:
http://lawnandgarden.manualsonline.com/ex/thread/view/idThread/340092
Posted on Aug 03, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
farmerbear
  • 490 Answers
SOURCE: I need to know what
It is the same as for the Craftsman 50" deck. The Sears part number is 144959. It's available at a decent price at sears . com. Farmerbear at FixYa.com
Posted on Sep 29, 2010
lene8
  • 6 Answers
SOURCE: looking for size of mowing deck belt for LT 4000 42 inch cut craftman Model 944604250
Most all auto parts stores can give you the size.
Posted on May 06, 2012
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Can you email the mower(cutting belt) diagram for the Husqvarna LGT 2654
hi there pauly46 here
check out this web site
http://www.partstree.com/parts/?lc=husqvarna&mn=LGT+2654+%2896043003600%29+%282007-05%29
or take a look at this site
here is web site for lgt 2654 owners manual , it has belt routing , and deck installing / removing instruction in it - quite helpful
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602053.pdf
cheers pauly46 hope it helps
Apr 09, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I need to know what size blade belt I need for my craftsman lt2000 42 inch mowing deck... the model number is 917273130
it's a 95.5" belt... you can cross reference most belt part numbers on the Dayco website
Sep 27, 2010 | Craftsman Garden
Lgt 2654 runs fine. But when I engage the mower it pulls the engine down alot and when I start to mow it really pulls it down and it hammers. All the pulleys and idlers are free.
Sounds like the mower belt may not be routed correctly around the pulleys or may be running on the wrong side of a belt guard. Also check under the deck to make sure there are no obstructions to the turning of the blade or bent blades....you did not state where the hammering was coming from ( engine or deck ) I can only assume that it is on the deck....so these are the things I would check. Also check the tightness of the bolt on the main pulley sheave (the pulley on the bottom of the engine that drives the belt. the bolt is in the center hole of the pulley) if it is loose it can cause misalignment of the belt and juddering of the deck. If the bolt is tight, remove the belt from the engine pulley sheave and start the engine and look to see that the crankshaft is not bent causing the pulley to wobble....worst case scenario....will require new engine...hope this helps... ;-D
Jul 03, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need mowing belt for 54" deck
It appears there are two belts for your mower. The primary belt is JD part M143019 and secondary is M118685. Your traction drive belt is p/n M127523.
The secondary belt for a 54 inch C deck is M154960 the other belts are the same as above.
I have used these folks for replacement belts before.
http://www.mfgsupply.com/MowerBeltsJD.html
I hope this helps.
Jun 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Belt diagram
Aug 03, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
