Can I replace Samsung HM321HI ATA hdd for by ST500 LT012-9WS142 SATA hdd ?
I have a Dell Inspiron Laptop with the samsung HDD. I also have a HP laptop with the ST500 HDD. I wanna replace the first one with the 2nd. Will it be ok to do so?
    Top Expert:
  • Computers & ... Master
  • 75,417 Answers
ATA and SATA are not compactable.
Posted on May 08, 2014
  • 70 Answers
SOURCE: laptop cannot see externa drive
do you get a LED blinking ? is there power on the drive? Is the Activity LED blinking as well?
Posted on Dec 24, 2007
SOURCE: Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
Posted on Jul 19, 2008
preachw996
  • 1179 Answers
SOURCE: HDD is cactus, what are replacement alternatives for the OEM?
You can use any 2.5 inch ATA/IDE drive as a replacement. Notebook hdd's are a smaller size than regular desktop hdd's. You can find a good idea online at stores like tigerdirect.com or newegg.com. Hope this helps & please rate this answer fixya. Thanks.
Posted on Feb 04, 2009
bob_computer
  • 3153 Answers
SOURCE: new Samsung HDD hangs up with boot
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
If it IDE make sure that the master / slave jumper is set correctly and also double check your power connection
Posted on Sep 22, 2009
  • 10406 Answers
SOURCE: Replacement hdd for a Toshiba MK4026GAX (ATA)
Any brand-new ATA hard-drive (you probably won't find any new hard-drive smaller than 80GB) will be compatible. Pay a few extra dollars for a 7200 RPM drive (rather than 4200 or 5400 RPM).
Posted on Nov 14, 2009
Testimonial: "I was thinking along those lines as I am considering a Seagate (Barracuda?) ST910021A drive. Many thanks."
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
I wish to Upgrade My HP Pavilion ZD8230US 100GB ATA HDD to one that is faster and has more Maybe as high as 500GB. SATA type drive would be great to have but unsure if I can install SATA Drive in this...
yes you can upgrade your hard drive but still on ATA,if you upgrade in SATA you need some converter from ATA to SATA .and since it's a laptop i think its hard to do that thing.
Sep 13, 2011 | Computers & Internet
I want to diassembel my samsung S1 Mini external hardrive 160 GB.I want to know if i can use the hdd on Dell D430
no i wdnt because its 1.5in instead of 2.5 2.5in is the standard laptop hdd hered one i got for my dell vostro http://www.overclock.co.uk/product/160GB-SATA-25-inch-5400RPM-8MB-MDT-Notebook-HDD-OEM_19684.html
Oct 22, 2010 | Computers & Internet
How do I replace the hard drive in my Dell
Did you format the drive before installing it on your laptop. Some laptop will not detect unformated hard disk. Try to format the hard disk somewhere else and check to see if the laptop detect it after.
Apr 11, 2010 | Dell Inspiron 2650 Notebook
I got a dell inspiron 1525 laptop..i'm unable to instal RHEL 5...it is showing the error that no hdd is found..how can i install RHEL 5
Since the Redhat install is not seeing the HDD controller, you'll need a sata controller driver to load at boot. You can try this one
http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=RC1084719&l=en&s=k12&releaseid=R129572&formatcnt=1&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=172694
Nov 25, 2009 | Dell Inspiron 1525 Laptop
HDD wont fit!!
Just looked at the details that are stored on fixya, I see the laptop would have a SATA connector, so the new one is IDE? you will have to get a SATA drive and it should fit. well compair the original to the new one, the one with flat connectors fits?
Jun 15, 2009 | Dell Inspiron 1521 Notebook
Need motherboard for qosmio laptop. do I have to replace w/same
they make an ata to sata conversion cable that you can buy, look on the boxes of the hdd's most of them come with the converter that you need
Dec 03, 2008 | Toshiba Qosmio G15-AV501 Notebook
Laptop cannot see externa drive
Dec 23, 2007 | Western Digital imicro IM35ST320SI 3.5 IDE...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
