Question about Kyocera KM-1505 Copier
How to reach the fuser of 2030 mita - Kyocera KM-1505 Copier
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
MITA TA180 ERROR MESSAGE C6000
Fuser heater break
Fuser thermistor 1 detected less than
70°C/158°F for 10 s during warm-up and
ready in.
During warm-up, the temperature at the
fuser unit thermistor 1 does not rise by
1°C/1.8°F continuously for 5 s.
Fuser thermistor 2 detected less than
40°C/104°F for 10 s during warm-up and
ready in.
fuser unit thermistor 2 does not rise by
Defective fuser
heater 1 or 2.
Replace the fuser heater 1 or 2.
Installation defectiveness
on fuser
thermistor 1 or 2.
Check the mounting state of the fuser thermistor
1. If any problem is found, repair it.
Defective fuser
thermostat.
Replace the fuser thermostat.
Defective PWB. Replace the power source PWB or engine
PWB and check for correct operation
Jan 08, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
I Keep getting a j10 display when I try to print on the display
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Peter
Dec 18, 2013 | Kyocera Mita Mita Copier Toner Cartridge...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
MAINTENACE TIME DISPLAYED ON MY km-2030
You need a technician to install a Maintenance kit. It consists of a new drum, developer unit, fuser and feed rollers.
Jun 02, 2010 | Kyocera Mita Office Equipment & Supplies
Mita all copies have clean, thin, black streaks
Needs a clean around the fuser area. You may see a build up of toner near the rollers which is being drawn in. There's an outside chance that the lens needs cleaning also.
Jul 07, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Kyocera KM-1505 Copier Logo
20 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
