Question about Garland Kitchen Ranges
Garland tg2a What is the burner gas pressure. It has had the mod kit fitted. Data plate says 3inches, but the flame is yellow
  • 23 Answers
If you are now using Propane the pressure needs to be 11 inches WC. Propane uses low volume, high pressure gas to pull in primary air. 3 inches will not pull in enough air for complete combustion.
Posted on Feb 19, 2015
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
  • 131 Answers
SOURCE: burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Posted on Mar 10, 2008
joboo1
  • 257 Answers
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Posted on Feb 10, 2009
VtToolMan
  • 704 Answers
SOURCE: Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Posted on Jul 30, 2009
EMSRSERVICEG
  • 426 Answers
SOURCE: broiler flame too big, right rear burner has yellow tips. was converted from natural gas to propane
you can turn the supply valve down
Posted on Jan 13, 2010
Can i convert a garland mod g286 stove from natural gas by installing apropane regulator
no
the modification from natural to propane or from propane to natural gas requires a jet change for all burners and an air flow shroud position change to get the correct blue flame ( correct air /fuel ratio)
it is a job for a gas fitter who will have the correct jets for each burner and will know how to adjust the shrouds
Jul 12, 2016 | Garland Kitchen Ranges
Calor gas. one large burner keeps sooting up with yellow flame and black soot. Others all ok with strong blue flames. Is there a cure?
It appears to me that the burner is no getting enough air.
The burner could have something blocking it. I've seen spider webs in types tubes. I'm not familiar with the cooker or the had pressure it should be set at. Where I live it would be a job for a licensed gas fitter. If its 2.75.kpa. Has that burner been fitted with a jet for 1.25 kpa?
Jun 17, 2015 | Kitchen Ranges
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Yellow gas . cleaned burner which is made by Worgas. Still yellow tipped
yellow flame is caused by low o2. so open air shutter or lower gas input. that said if flame is equal across burner.a normal gas pressure to the burner is 3.5 " w.c. there should be a test port on outlet side of valve. the name plate will tell you what the pressure should be.
Jan 04, 2011 | Desa International GWP20T GLOWARM Wall...
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE BURNER INSERTS INTO THE GAS VALVE. THIS PLATE CAN BE ADJUSTED TO ALLOW MORE/LESS AIR TO THE BURNERS BY SWIVELING THE PLATE .CANTHESE BE REPLACED
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Mar 30, 2010 | Lynx Grilling
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Garland oven MOD# MST43RE White flames and a lot of black.....
I adjusted the air mix, main burner was full of black stuff inside so took the air compresor and cleaned it good. Now i have nice blue flame!
Gasman77
Mar 25, 2009 | Garland M-2 Oven
Ovens won't work.. pilot safeties keep dying..
Hi, just wanted to ask, are you sure the safety valves are bad? seems strange that 2 would go bad like that. I have seen thermocouples ( $7 to $12 ) improperly installed,routed, not an OEM part,dirty pilots, affect them alot more often than a bad safety ($150 to $250). There is no baffle plate behind the safety, however, if mounted properly, it should be well out of any heat range that would be causing any problems. Are you sure it isn't "front venting" ? meaning the exhaust, or part of it, has to escape out of the front of the unit, causing it to overheat? this can be caused by a few things, something blocking,covering,in the flue. Your gas pressure too high, or no regulator at all, sooting, clogged orfice causing gas to burn in the burner, alignment of orfice to burner, etc.. Hope all that helps, let us know :)
Dec 31, 2008 | Garland H283 Gas Kitchen Range
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
83 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
