Question about Grizzly Big Bear Atv Maintenance Free Battery
How to locate IAT sensor on 2009 yamaha grizzly 550
  • 20 Answers
IAT stands for intake air temperature, the sensor is going to be located in the air snorkel tube/box air cleaner or the tube before the carb/throttle body (usually has 3 wires, reference voltage, ground, sensor output)
Posted on May 14, 2014
I HAVE A 2009 YAMAHA GRIZZLY 550. I JUST REPLACED THE BATTERY AND NOW I HAVE A BIG E ON MY DISPLAY HOW DO I CLEAR IT SO THE DISPLAY IS NORMAL AGAIN
Unfortunately, you have to buy a new display! It is a design flaw.
Yup big flashing E and it's done, you can contact your dealer if you want to make sure, if you have a warranty it should be covered. For some reason the meter peters out under low voltage, something I can't quite get my head around but it's happened to a lot of folks.
Your quad will run fine with out it, I found one for 237$ at foxyamaha dot com, it's under meter. I've heard there's an upgrade on the newer ones, but I haven't found anything official saying that, might want to make a few calls.
Flashing on the dash
Jul 04, 2016 | Yamaha 2009 Grizzly 550 FI Auto 4x4
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
HOW MUCH GREASE WHEN REGREASING AN ATV CLUTCH,550 EPS YAMAHA GRIZZLY,
Put enough grease to cover the rollers. Also add some to the actual tracks where the rollers glide on. The clutch should have a thin cover that is held on by three small screws. that is your "grease cap" If there is too much grease it'll end up there. Hope this helps. I own older grizzlies and that is what has worked for me.
Nov 20, 2013 | Yamaha 2011 Grizzly 550 FI Auto 4x4 EPS
Stator Cover Removal on a 2009 Yamaha Grizzly 700
can't get the screws loose ??? try a tool called an impact driver... Harbor Freight
Nov 16, 2013 | Grizzly Big Bear Atv Maintenance Free...
Yamaha Grizzly 350. After riding for twenty or so
These quads have a thermostat-controlled radiator fan, which won't turn on until the engine is hot. Perfectly normal. Also, if the fan comes on, make sure you use the kill switch to turn the quad off, rather than just turning the key. This allows the engine to cool properly and will save your engine gaskets and other parts. It could take quite a while to cool down...my 2009 Grizzly sure does.
Jun 16, 2010 | 1985 Yamaha XZ 550 S
I need to locate IAT sensor four my 2009 ford
The IAT is integrated with the MAF sensor on the 09 Fusion. The MAF is located near the air box on all three engines. on the driver's side, and will be held to some part of the intake tubing by 2 torx screws. http://media.photobucket.com/image/2009%20Fusion%20MAF/itsamecameron/fusion4cylengineMAF.jpg 2.3L shown, 3.0 and 3.5 should be similar.
Oct 04, 2009 | 2009 Ford Fusion
Grizzly Big Bear Atv Maintenance Free Battery Logo
102 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Coss
Andrew Taylor
Andrew Taylor
ray012965
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
