Cars & Trucks Logo
Lorne Simmons Posted on May 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrical problem I have a 2013 KIA RIO and I had a problem with the battery not holding charge,dealership changed battery,same problem,dealer check charging system OK check new ba.and it reads faulty change,so they put in another new bat. problem solve3d i thought,now my radio speakers keep chanmging from R toL or front to back on its own also light on air always came on when on defrost,now it don;t but it will come on if turned on maually,what is the problem the dealership can't or don't want to find ?
David Burbee
Level 3:
  • Cars & Trucks Master 1,871 Answers
  • Posted on May 08, 2014
David Burbee
Level 3:
Answers
1871
Questions
Helped
1056043
Points
1009
I suspect a resistive ground between negative battery post and chassis...If you have an ohmmeter and a wee bit of knowledge on its use perform the following test...Set meter to read X- 10...Engine off...Place one lead on the center of the negative battery post...The other on bare metal of fender...You must read close to zero ohms...while holding the lead on battery negative post place the other on bare metal of engine block...Must read close to zero ohms...If you read 500 to 2000 ohms you have located the fault...Run test and give results...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Oct 19, 2008
SOURCE: 1998 Ford Explorer
had same problem when my rear wiper motor went out. I had to locate all the rear wiper motor fuses and take them out to stop it. Am now waiting to replace my wiper motor.
Anonymous
  • Posted on Nov 16, 2008
SOURCE: 2000 lincoln ls : check charging system light
You could have a bad connection somewhere. Possibly on the alternator. You also may have a bad ground somwhere. Hope this helps any
travislg4
  • 27 Answers
  • Posted on May 24, 2009
SOURCE: new battery and alternator. Battery still won't hold charge
Check all your fuses if you had a system failure it could have blown a fuse. I am not sure on your vehicle where the fuse is in the car or under the hood it could also have a relay. You can check your alternator by checking the voltage at the back of the alternator where the big wire bolts on. You should have 14+ volts at the alternator.
Anonymous
  • 1959 Answers
  • Posted on Jul 04, 2009
SOURCE: Kia Rio overheating although everything seems ok
Possible early signs of a water pump problem. A failing waterpump will circulate coolent when the RPMS are high but when you slow down, so does the waterpump, thereby causing overheating.
Anonymous
  • Posted on Oct 30, 2009
SOURCE: dash board lights on grand voyager flashing when
the controls always click when you change the setting as it is electronic, don't panic, but you should ask your ex as he is well up in voyager' s and the back seat not folding down properly!!!!!
1helpful
My 2013 Kia Optima makes a clicking noise and won't start. Just had it at dealership two days ago.
1. Check that the wiring to the battery is tight on the battery terminals and the terminals are clean. Try and jump start the car from another vehicle. If it starts then your battery is bad and needs to be replaced. Also have the alternator checked to ensure it is producing the required electrical current to run the vehicle and keep the battery charged.
2. If it does not start with an attempted jump start off another car and your car is still under warranty get the car to the dealer and get them to check the " brake sensor". If the sensor is faulty your car will not start. However with this condition you would not usually hear any clicking either.
What must i strp inside my kia rio 1.4 2013 to change my gear shift cable that snapped
Dimanche T bar shifter and console it should bolt to the end of T bar and unbolt at gear selector.
How do I change headlight/turn signal switch on a 2013 Kia rio
I would call the dealership and find out if the vehicle is still under warranty, since it is fairly new.
2008 Kia Rio radio code please
HI code is given by dealers on radio folder in service books .if not visit your KIA dealership with vehicle registration papers,they will assist.
2002 kia rio will not shift out of second gear in drive always starts in second from drive position. Sometimes it will go into first gear roughly others not at all. Dropping down ton first on the...
First off have a load test done on the battery as there is a dead cell evident. Run fault codes and look for a problem TCM (transmission control module) which may be affected by the battery fault. Have a pressure test done on the transmission to check for internal problems. Check oil level when hot.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
