Question about Whirlpool Refrigerators
Whirlpool wf225rxg fridge leaking water - Whirlpool Refrigerators
the dr
  • 447 Answers
SOURCE: whirlpool fridge freezer with ice dispenser
replace the water valve located where water line goes to refrig.
Posted on Jan 15, 2008
  • 909 Answers
SOURCE: dripping water inside fridge. Can't find drain hose
at the rear of the fridge unit there is a hole, normally at the bottom of a shallow "v" shape. there should be a plastic insert in it to clear any blockages, just wiggle it a bit. failing that a pipe cleaner will do the same.
Posted on May 02, 2009
  • 9 Answers
SOURCE: Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
Posted on May 12, 2009
Maytag317
  • 1136 Answers
SOURCE: leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
Posted on May 15, 2009
  • 67 Answers
SOURCE: Ice/water forming under fridge hydrator.
The tray slides out, take it out and dump it, clean it and replace it every year. This is where the coils drip to when the humidity is high or it is working hard to keep cool, like if you just had a party and everyone was in the fridge.
Posted on Aug 16, 2009
Why is my 2002 Whirlpool top-mount Refrigerator leaking water inside the fridge. About every two weeks my fridge leaks water in the inside, not enough to run on the floor but, must remove everything to...
Check the defrost drain/trap, its clogged, so the water cup is overflowing and water runs down the inside back of the unit. Clear the drain/trap and it should be fine.
Feb 24, 2015 | Whirlpool Refrigerators
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Fridge leaking water
The drain line may be misdirecting the defrost water so that it misses the pan or the pan may be damaged or mispositioned.
Dec 03, 2013 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Have whirlpool gold refrigerator with freezer on top. Water leaking continuously out bottom on floor. I turned water valve behind to off. All leaking stopped. Can someone tell me where to look for the...
One big question before you go hunting. Before you turn off the water, was the water running all the time? Meaning if the water had a continuos flow the leak is before the fridge. If the leak is erratic then its on the valve side to fridge.
Follow the water source in the fridge, supply line to water valve (bottom right behind the fridge), from there it should run straight up the back into the freezer. So, if the water is coming from the valve, replace it, if from the water line - replace it. If the water line came off or out of the freezer reconnect and check for a frozen fill tube.
I hope this information helps.
Oct 21, 2013 | Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water leaking problem
Is your fridge standing on a flat surface without any tilt in it? Many floors are not absolutely flat in which situation my fridge leaks too.
Aug 22, 2009 | Whirlpool Refrigerators
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Whirlpool REfrigerator Freez WRN38RWG6 How do you stop water
Turn Fridge off,leave open for 24 hrs,then shut doors and start.The defrosted water had frozen up high and the fridge then leaks
Mar 01, 2009 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
