SOURCE: panasonic dmc-fz5
I posted a solution yesterday on Fixya, but can't find it. Same problem, same camera, solution reached on Feb 10 2009 after a couple days of frustration. I gently wiggled the lens by pushing my fingers one on either side (not the outer ring, but the inner ring, but keep your fingers off the glass part). It moves perhaps a fraction of a millimeter, but it moves. After I did that, the problem went away. It's hard to describe, just a gentle 3 or 4 times push on either side; you may have to change finger positions to get the movement. It apparently only takes this to get the lens back on track. Good luck, it's a great camera. Lee
SOURCE: Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
SOURCE: when zooming, when it gets to 3x zoom, error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: Panasonic Lumix digital camera DMC-F27
Hello
That is a sign of lens problem. Try gently - moderate tapping the camera repeatedly, with the lens facing the ground.
