Question about RCA F32650 32" TV
Squealing sound coming from Electrical Component on board. Electrical Component is about 1 and a half inches in length by 1 inch in width by 2 inches in height. Center of Electrical Component appears
No Picture or sound. Just plug in and Squealing sound comes from that Electrical Component on the circuit board.
    Top Expert:
  • RCA Master
  • 75,169 Answers
Sounds like FBT [Flyback transformer] fault. Contact any service technician. Gopakumar Gopalan Google
Posted on May 08, 2014
5 Suggested Answers
  • 556 Answers
SOURCE: High Pitched wine when turning on
yes it is worth fixing & not that serious. but please call skilled tech to fix it as high voltade is inside even it is off.if you are not a tech person.
Posted on Sep 30, 2007
  • 1694 Answers
SOURCE: i found chirping noise problem
Tv is in shutdown mode caused by bad flyback transformer..
Part # 257805 or ASTI 2078......common problem, but TV
repair skill needed.........................T.
Posted on Dec 11, 2007
jerryg50
  • 1689 Answers
If your set is an RCA which I believe it is, you can contact RCA to find their part distributor for your area.
How did you determine that these parts are acutaly defective???
When these types of parts are defective, the cause must also be found. When replacing the parts, they will probably fail again unless the underlying cause is found. This will require the proper training, service manual, TV service experience, and the proper tools for troubleshooting.
As for changing the parts, you will require the proper tools and soldering equipment. After all the faults are found and the parts replaced, and the set is working, it is best to verify the power supply performance, the high voltage regulation, and the operating temperature of the various components effected in order to insure reliable after service operation.
Jerry G.
Posted on Apr 13, 2008
  • 223 Answers
SOURCE: horizonal line
I think you have a fault on the picture frame board. If you can check for this yourself or find a competant technician. Hope this helps.
Posted on Oct 03, 2008
The length of a triangle is 4 inches more than twice the width. if the perimeter is 88 inches, what is the length and width of the rectangle?
Your answer to this question will be 2.5 or two and a half...
Pick a number, multiply it by 2, add 5, divide it by 2, and subtract the answer you get from the number you picked...your answer is 2.5....
Jan 31, 2018 | The Computers & Internet
The length, l, of a rectangle is 5/2 its width, w. The length, l, of the rectangle is 10 inches. What is the perimeter of the rectangle? What Iis the area of the rectangle, in sauare inches?
We are given the following data:
length = 5/2 * width
length = 10 inWe know through the transitive
property of equality that the following must be true:
5/2 * width = 10 in
We then solve this equation algebraically for width:
width = (10 in) * 2/5
width = 4 in
The perimeter of the rectangle is given by substituting our known values of length and width into the following general equation:
Perimeter = 2 * length + 2 * width
Perimeter = 2(10 in) + 2(4 in) = 28 in
In a similar fashion, we substitute these known values into the general equation for the area of the rectangle to solve for the same:
Area = length * width
Area = (10 in)(4 in)=40 in^2
Nov 29, 2016 | The Computers & Internet
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
Squealing Component: PN 1536335A; D1 15303340; RXETEED2434.
You're discussing about its SMPS transformer at its main power supply section circuit; I assume. It it sounds [like a buzzer]; check for any loose fitting with its ferrite core.
May 08, 2014 | RCA F32650 32" TV
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Apr 08, 2014 | Cars & Trucks
What are the dimensions of the 3/4 sleeve Henley shirt?
According to Walmart's website, in inches the shirt is Length 6, Width 6 and Height 1. If that isn't helpful, I have the same shirt and it comes down to my hips. I'm 5'5.
Feb 16, 2014 | Faded Glory Clothing
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Dec 09, 2008 | Electric 1/2hp 1140RPM 56 Frame 230/460V...
RCA F32650 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
