Question about Hoover Vacuums
Hoover U6630-900 Self Propelled WindTunnel Bagless Vacuum - Stuck on "Brush Roll OFF"
We recently acquired a Hoover U6630-900 Self Propelled WindTunnel Bagless Upright Vacuum Cleaner series X 12.0. The "Brush Roll" option is stuck on OFF and the roller will not spin. The belts are good I believe. We checked and found two belts inside. There is no smoking or smell of anything burning. The "Floor - Carpet / Hard" switch may be to blame. It does catch a little when it is slid all the way to the left or right. It slightly clicks into place, but when sliding it through the middle, there is no resistance at all. My husband and I are mechanically capable and may be able to fix this with a little guidance. Any help you can give us would be great! (No it is not under warranty. I purchased it secondhand and got a great deal because of this problem.) Thank you!
  • Shelly Fradkin May 08, 2014
    By the way - the roller has been cleaned and it does roll freely.
    Top Expert:
  • Hoover Master
  • 35,552 Answers
You may have to do some disassembly to gain access to the mechanism but you will find it's a rather primitive arrangement that tends to fail over time. If no broken parts are found, some experimental testing will reveal what has to be repaired or adjusted to restore normal operation.Be sure to test "switch" movement as you reassemble to detect binding caused by tightening hardware.
Posted on May 08, 2014
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
reddevil6
  • 1673 Answers
SOURCE: Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Posted on Sep 18, 2008
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6634-900 self propelled, brush belt keeps coming off.
unfourtunatly it could be the height of your carpet also using on area rugs could cause it to do that too. check the brush roll and make sure it is spinning freely.
Aug 29, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Windtunnel self-propelled feature broken
If it is a rubber smell, then it could be belts and/or brush roll. If it is an electrical smell, then it could be the motor. Take the belts off and see if it still makes that noise, if it does, then the motor is going bad.
Apr 22, 2008 | Hoover Self-Propelled WindTunnel Bagless...
BELTS ON WINDTUNNEL VACUUMS
Here's an instructional video that we made showing how to change the belt on a Hoover Windtunnel upright. If your model is not a self propelled model, basically follow the same insturctions, expect instead of placing the belt over the pulley, just put the belt through the roller brush, and stretch the roller brush back into the agitator housing.
Please feel free to send me an email if you have any other questions. My email address is chris.jones@govacuum.com.
Thanks,
Chris Jones
GoVacuum.com
Mar 16, 2008 | Hoover U5753-900 WindTunnel Bagless...
Self-propelled windtunnel bagless
Either the inlet down by the brush roll is clogged, or the hose is clogged. Check that out and if you still have a problem, then take it to a warranty repair shop, you have a 1 year warranty on this. Take your sales slip as proof of purchase.
Feb 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover windtunnel Self-propelled - brush roll stops
There is a idler wheel that will drive the V belt, sometimes they jam and you just have to reach in, push and make sure if comes in contact with the belt. Alot of times tho it is the other flat belt, 38528035 that will stretch and can cause you to have problems with the brush roll not turning.
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
