Hi sense air conditioning unit displays COMP, what does this mean?
It has a red light that says comp. We turned it off and on again and it said 'gulag' and then started working again but still displays comp. What does it mean.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 159 Answers
Have your compressor checked
Posted on May 08, 2014
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
SOURCE: My Thermostat is flashing "L6"
The battery needs replacing.
Posted on Oct 18, 2008
  • 7 Answers
SOURCE: EverStar MPM2-10CR-BB6. Comp. only runs for about
check the start gear for the comp.
Posted on Jun 27, 2009
  • 9 Answers
SOURCE: hi, i have 2 daikin air conditioning unit, 1 is
The flashes are codes for different problems the unit may have, count the flashes and check your owners manual this will tell you the problem and the solution, or turn the breaker off for 5 minutes and re-start the unit this will reset it the unit should work if the problem start again you will need a service man. hope I was able to help you.
Posted on Jan 29, 2010
Comp kicks in/out every minute
maybe your evaporator unit is very dirty and the temp. sensor has dirt on it so this way senses cold faster and kicks out, or the temp in your unit is set to hi or you could have an electric electronic roblem, i recomend you go for a preventive maintenance
May 29, 2014 | LG LMU240CE/LMAN090CNS Air Conditioner
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and...
every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Oct 14, 2013 | Heating & Cooling
Mitsubishi legnum/galant air conditioning not working
Pull the power wire from the ac comp see if you have power to it with switch on , no power check for loose wire connections under dash if you have power to the comp but it won't kick in sounds like a low from level in the system you can check that by jumping the the pressure switch with a paper clip to see if the comp kicks in
Mar 12, 2013 | Air Conditioning and Heat for Mitsubishi...
My acer aspire t180 ua380a desktop comp will not post. I turn on the comp and the red light comes on but no green lights and again the comp will not post. I have reseated the ram and cpu.
If it won't post you have a bad memory chip or memory slot try a different slot. Do you have more than one stick of ram? if so remove one stick and try it in different slots, if it does not post then buy some new ram.
Jun 13, 2009 | Acer Aspire™ T180 PC Desktop
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
PROBLEM W/ CASIO fx-260 SOLAR
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Jun 04, 2008 | Casio FX-260 Calculator
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Heating & Cooling Logo
241 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
