Question about Apple iPad (16 GB) WiFi Tablet PC
My apps on my iPad keeps shutting down - Apple iPad (16 GB) WiFi Tablet PC
    Sergeant:
  • 258 Answers
Is it just one app or more than one you need to be more specific.
If its just one app remove it and reinstall it!
If its all apps then you either have a virus or an OS corruption.
Sounds like a virus or corruption - take it to an apple store i believe they will fix it for free if its still under warranty - other than that its a technical fix involving the removal and reinstall of the os through the Apple Itunes.
Posted on May 13, 2014
I rebooted my tablet but why is it still keep freezes?.
ive noticed this happening with my tablet and this can happen if there's too many apps trying to start in the background (resetting may help the tablet power off the tablet and hold the power key and volume up (or down) and select wipe user data/factory reset (warning: anything on the device WILL be lost!) before doing the reset make sure you can recover your files first!!
Apr 21, 2017 | Tablets & eReaders
Apple i-pad air boots up to a larger screen,the touch icons are hard to move.
Hi Julie
If by larger screen, you mean Zoomed screen, it could be that you have turned on zoom in Settings / Accessability.
Also.... the iPad is "booted up" all the time. Generally all you are doing is Waking the iPad from sleep or screen in sleep mode.
To ReBoot your iPad (worth doing every month or so) First quit all Apps by double clicking round button and individually swipe each open App upward to shut the App down. When all apps are turned off, Hold the Top button & Round Button in together for about 5-10 seconds. This will shut the iPad down completely. When all off, Press the top button in for about 5 seconds. You will see the Apple logo while it ReBoots. This usually fixes any minor glitches etc in the Apps. If a particular App is giving problems, you can hold your finger down on it till the X shows in the LH Top of its icon. Click this and it will be wiped off your iPad. Then re download it for free through the App Store and check to see if problem has gone.
Hope this proves useful.
OJ
Nov 02, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My app won't work on my iPad mini when I touch it
As soon as your iPad starts acting strange, it is time for a reset.
you can do this by simply closing all running apps. Press the home button twice and then swipe all apps up. They are closed then.
If all apps are closed, press the on / off button and keep it pressed till it says swipe to shut down. Swipe and wait till everything is out.
Then press the on / off button again, for a second or so. The iPad starts again.
Somewhat drastic, if you can't switch it of the normal way: Press and hold both, the on / off button and the home button, till the screen goes dark.Then the apple loge appears and again wait till the screen is dark. After that you can switch on again.
If it still does not work, goto settings then general then scroll to the bottom, where it says reset. then reset network settings. It will reset your network settings, but also the rest of the iPad. This is the most dramatic reset, without loosing your apps and documents.
One step further will wipe your data too, so that you must keep for the worst case and only after you are sure you have a backup on your computer from all your data.
Apps can be restored from the App store for free, if you have payed for them, but the data, unless you have backups, will be lost fro ever.
Oct 21, 2014 | Apple iPad Tablets & eReaders
Facebook comes on then goes out
This is usually a memory error. You may have too many apps open and need to close them.
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
After closing all the apps you should then shut down the iPad completely. You can do this by holding the sleep button on the top edge for about 5 or more seconds. You will then see a slider on the touchscreen pop up that indicates you can shut down the device. After it is completely shut down, count to 10 and then press and hold the same sleep button on the top edge for 5 or more seconds to reboot the iPad. You can also plug it into your computer or charger at this point to force the iPad to turn on.
Sep 23, 2014 | Apple iPad Tablets & eReaders
Why does my ipad16GB keep shutting down while I'm logged into Facebook?
Many "shutdown issues" are caused by over taxing your memory with open apps.
Double click the home key to view the open programs at the bottom. Tap the "-" signs to close most if not all apps. Swipe down or click the home key to return to the main screen; then try again.
Sep 08, 2014 | Apple iPad 2 Wifi 16GB
My iPad shuts down while I'm on Facebook all the time. How do I fix this problem??
If it is only the Facebook app that is causing this issue, I would just uninstall Facebook and reinstall it.
Sep 08, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How to delete apps in iPad
On the homepage of your iPad > find the app you want to delete > long press it until it wobbles > press the cross on the top-right of the app to delete it.
Sep 03, 2014 | Apple iPad 32 GB 3G Tablet PC
How to close down apps on an ipad
Double-click the Home button and you will see small windows of all the Apps that are currently open. Swipe upwards on one of these windows and it should close. You can continue this process on any other Apps that you wish to close.
Mar 15, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
Dec 09, 2013 | Tablets & eReaders
Won't let me play pogo games on apple computers
If you haven't already done so, you have to download the Pogo application from the iTunes app store. If your problem is with the app itself, the first step would be to reboot your device. To reboot the iPad, hold down the button on the top of the iPad until you get the option to shut down the device. Once shut down, press the same button to power on the iPad. Test the Pogo app to see if it works now.
Jan 04, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
44 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
