Question about Whirlpool duet Washing Machines
HOW TO REMOVE COMPLETE PUMP
WFW9151YW00
    Problem Solver:
  • 15 Answers
Un plug unit from power. then tip machine towards back and remove lower front panel, then there are 2 hex screws coming up through bottom of machine that go into pump. remove inlet and outlet hoses and a wire harness and its out. installation of new pump is reversed.
Posted on May 13, 2014
I have Duet waSher, model #WFW9151YW00. I have an error code F3E2. Thought it was the temperature sensor, which we just replaced, but still getting the same error code. Now what?
This could be a wiring fault between the water temperature sensor and the control unit. Make sure that the connectors are properly seated at both sides. Sometimes, one section of the wiring can get pinched and one of the wires in that harness could break. Check that all of the wires in the harness have continuity; the wiring may need to be replaced. Clean out the trap before the discharge pump just in case the error is from a different part of the washer's system.
I hope this helps.
Dec 01, 2016 | Washing Machines
Hello I have a front load washer whirlpool WFW9151YW00 I keep getting error codes F7 and E1 also not Spinning or Agitating
press power,this cancels the cycle and should clear code. then press power and select rinse/drain and spin it should be back to normal. if not you will need an engineer...Adrian,,,
Jan 27, 2015 | Whirlpool Washing Machines
Srmw 2.2g26. Can the pump be rebuilt with a kit?
There are two options for this pump regarding rebuilding it. You can purchase all of the repair kits individually, or just buy the complete replacement pump head with all components already installed. This is the easiest/most reliable way to address the repair of the SRMW pump. It is also extremely easy to install, and can be done in less than a minute since you do not even need to remove the pump from the pressure washer (this is the complete pump head that can be found online:
http://www.ppe-pressure-washer-parts.com/product/1001.6677
Oct 03, 2013 | Briggs & Stratton Garden
How to remove old water pump
Not knowing which vehicle you have mot water pump removal is similar start by removing the radiator and fan shroud then continue to work your way back toward the water pump remove all belts then the fan and pulley assembly this should expose the water pump remove the 8 to 10 bolt on the pump itself use a putty knife to break the seal and work the pump back and forth til it is free. this is a simple but labor intensive fix figure a a day to complete removal and installation
May 13, 2011 | Oldsmobile Cutlass Ciera Cars & Trucks
I have to replace fuel pump, do you have a procdure to replace fuel pump in 2001 focus wagon, 2.0 split port engine. thanks.
There is a complete guide to remove and install fuel pump.Its a complete procedure.Click this link directly:---- http://technoanswers.blogspot.com/2011/04/how-to-replace-fuel-pump-on-2001ford.html -------------------- Read the instructions mentioned and follow it properly.This will help to replace the fuel pump .Thanks.Helpmech.
Apr 05, 2011 | 2001 Ford Focus
My Whrilpool dishwasher--DU8505SWPQ3, there is always water left on the walls of the dishwasher after a complete cycle is done??? Thanks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Feb 08, 2011 | Whirlpool Dishwashers
Wont drain water after cycle is complete
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If it doesn't spin or pump, but will agitate, it could be that your pump is seized or something is stuck in it. The agitator is operated by a different motor. Turn OFF the power. and remove the front vertical panel by inserting a drywall knife in a the top right about 4" in from edge at the joint 1" down from the top, push the clip towards the back of the machine to release that corner, get another knife and do the same to the left top corner, the pull the top of the front panel toward you and swing down, then lift off and remove. Disconnectt the two hoses to the pump, one from the drum the other that goes to the back. Be ready for a considerable amount of water to come gushing out, use a hose to direct to a floor drain. Check to see if something is stuck in the pump or the hoses, remove it. Check to be sure the impeller spins. If you found something restricting the flow or pump, remove it and re assemble. If the impeller won't spin easily, then you need a new pump.
Remove blockage in the pump. Re-assemble and test.
Nov 10, 2009 | Roper RAX4233PQ Top Load Washer
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
