Question about Siemens ultraStack WT46E300US Electric Dryer
What is a key sign on my screen
What is the solution
    Sergeant:
  • 479 Answers
Child lock usually takes two buttons designated by the facatory to be held for 3-5 seconds
Posted on Jun 29, 2014
Locked out of laptop Toshiba C55-A5220 screen on there is a power sign and a narrator sign
Look like the sticky keys are active. Tap Shift Key for 5 time it should opo up a message to activate or deactivate the sticky keys.
Oct 02, 2013 | Toshiba Computers & Internet
Change screen font and size
This amazingly easy trick will instantly enlarge hard to see text on your screen!
Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles!
Using these tips you can read screen text comfortably!
With the press of two keys, you can enlarge the screen text without going into your settings.
Simply press and hold down the "control" key, while pressing the "plus sign" key.
Be sure to keep the "control key" depressed while you press the "plus sign" key.
Each repetition will enlarge the text.
This can make reading small text SO much easier!
To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key.
Each repetition will decrease the text size.
also
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
Apr 23, 2013 | Compaq Presario CQ56-115DX Laptop
There was a percentage sign on the bottom right hand side of screen to increase or decrease the size of viewage
on the keyboard hold the "ctrl" key down and then press the + key to increase the size or press the - key to decrease the size
Apr 14, 2013 | Computers & Internet
Fix zoom level
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Mar 10, 2013 | Acer Aspire 5500 5570-2609 Laptop
How to make the letters bigger on my facebook account
Step 1:
Feb 07, 2013 | HP Computers & Internet
Get larger font on this computer
Hope this helps.
Jan 17, 2013 | Toshiba Computers & Internet
How do i change to font so that it will stay put it keeps going back to 12
Which programs font are you referring to ???
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . Hope this helps
Dec 13, 2012 | Acer Aspire 7250-bz600 Laptop
I accidentally shrank my web screen and I don't know how to zoom back into normal size. Help
Hi!
To zoom in or zoom out your web screen.. here's what you need to do.
ZOOM IN: Press and hold Control key (CTRL), while holding Control key press plus sign ( + ) to make your screen bigger.
ZOOM OUT: Press and hold Control key (CTRL), while holding control key. .. press minus sign ( - ) to make your screen bigger.
Hope it helps you.
Much appreciated if you rate this help.. thanks
May 19, 2010 | Computers & Internet
How do I ente 8x - 1 over 10 on my TI 84 plus silve edition
I am not sure what the cross (x) means: is it a multiplication or the variable x, so I took a screen capture of both cases.
The top case is obtained as follows the asterisk is the multiplication sign to thr right of digit 9; the small minus is the change sign key the minus sign in parentheses under digit 3 and to the left of ENTER key.; the forward slash is the division sign, above the multiplication sign.
This small minus called change sign makes a positive number negative and a negative number positive, hence its name. If your expression starts with a negative sign that is the one to use. Use it also for negative exponents.
As you can see the result is -.8. Notice how the - before the dot is small with respect to the regular minus, as in the last expression.
For the last expression on the screen capture, there is nothing special, except that you have two ways to enter the variable X.
1. Press [ALPHA] [STO->]
2. Press the key [X,T, Theta, n] to the right of the green [ALPHA] key.
Hope it helps.
If x is the multiplication sign
8[x] [(] (-)1
Oct 06, 2009 | Texas Instruments TI-84 Plus Calculator
Keys not functional though you can only switch the phone on
May be the phone is 'locked'. Check for a locked sign (probably a padlock sign) in the top edge of the screen.
Jul 13, 2009 | Nokia 6500 Slide Cellular Phone
Siemens ultraStack WT46E300US Electric Dryer Logo
160 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Mike
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
