Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do I get the clips off a washing machine filter?
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
You put a thin screw driver into a gap in the strap and lever it of ...then you need to tighten it with a long nose pl
Posted on May 08, 2014
    Genius:
  • Hotpoint Master
  • 1,474 Answers
The clip secures the SUMP HOSE which has the filter in it ,Put an old towel under this and give it a tap with a flat bladed screwdriver this will loosen the White clips that hold on the hose,then you remove filter and clean noting which way it came out , refit
Why wont the washer finish cycle? it pauses indefinitely after the wash cycle
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Kenmore 24 in. Electric Space Saver...
Why won't ariston 105 start spin cycle?
easy fix if so.
Hope this helps.
Aug 26, 2014 | Washing Machines
My thoshiba washing machine model aw-a820mm cant be on. when pressing on button it lights blinks n off in seconds. need solution?
This could be a blocked/air-locked filter. common occurance.
easy fix if so.
Hope this helps.
Toshiba washing machine AW-A820MM cannot be on. iwen press on button lights blinks for few seconds and off again. what could be problem?
easy fix if so.
Hope this helps.
Why will an amana front loader not spin
Sounds like this could be a blocked/air-locked filter. (a common occurance with all machines) not a fault
easy fix if so.
Hope this helps.
Aug 26, 2014 | Amana Washing Machines
My washing machine will not ruN through a complete wash cycle
This could be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
Hope this helps.
Aug 25, 2014 | Indesit Washing Machines
Where is the filter on a hotpoint aquarius 1000 washing machine
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Apr 06, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washing machine WF430- Where would my filter be located as it needs to be emptied?
Its located at the rear of the machine, adjacent the drain pump, held with jubilee clips. You only have undo the main one. Filter is like a small, holed basket with a plastic ball. Empty anything in there and make sure you place the plastic ball back, tighten jubilee clip.
Jan 04, 2010 | Hotpoint Washing Machines
WMA46 washing machine not draining, filter blocked but can't locate filter
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Jul 11, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
