Question about Palm AT&T C/PHONE PALM CENTRO S64801
Same problem as red light /hot sync issue phone dead.
Have exactly same problem, does anyone have any answers or suggestions. Phone is completely dead.
Well, this same problem happened to my phone after it got a bit wet. I think you should leave ur battery out for at least two hours, and then put it back in. it will turn on, and charge it im not sure if itll work for sure but my touch screen works fine and my keys work on and off but it still turns on and can be functional.
Posted on Jul 08, 2009
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
Samsung wep 150
then internal battery is dead sir
its clear
Jun 16, 2008 | Samsung WEP-150 Wireless Headset
Put the battery in the red light comes on and wont turn on
Will it turn on if the phone is plugged into the charger? Pull the battery, clean the terminals on the phone & battery, let the phone set or 30 minutes and reinstall battery. If it fires up, I would suggest syncing the phone immediately, then performing a hard reset and resync.
If that doesn't work , the battery could be the issue, but the phone is more than likely becoming unstable.
Sep 21, 2009 | AT&T Palm Centro Cell Phone - White
Logo keeps flashing and won't take a charge.
there might be a problem with the phone or USB cable that ur using for charging, you can have it checked by using another USB port on your PC, try using another cable as well if it did nto work the phone needs service.
Jul 02, 2009 | Samsung Rant Cell Phone
Palm centro
Your battery sounds as though it is completely dead. When a phone uses an application like hotsync this will deplete your battery faster than anything else. My suggestion is this, take your phone to a dealer store and see if they have the Palm Centro model. Have them insert their model battery into your phone to see if your phone turns on. If it does, then you have eliminated the probable cause of not powering on. However, this will not resolve the issue about the auto sync issue which I suspect is depleting your battery. This may require an immediate hard reset, which sets your phone back to manufacturer setting and you lose all contacts and dowloads on phone. The reps should be qualtfied to do your hard reset for you. If your phone stops acting up you've solved your problem. if your phone continues to auto-sync you'll need to take it for repair. There is usually a fee if you do not have protection on the device.
Aug 06, 2008 | Palm Treo 500 Centro
Dead phone
ive got exactly the same problem, can anyone help
Apr 07, 2008 | Sony Ericsson W550i Cellular Phone
Palm Centro
My daughter's phone had the same issue of the red charging light remaining on constantly and the phone not booting up....
I something similar happen to a PSP console too.
If you have a Sandisk or other type of expandable data card in the phone... remove it.
Remove the battery for about a minute and put the batter back in...
The data card is probably corrupt and needs to be reformatted.
I did this and the phone booted with no problems.
Just like my PSP.
Hope this Helps....
Feb 23, 2008 | Palm Treo 500 Centro
Charging lg kg 220 phone
Almost certainly liquid damage to the lower part of the phone!
Depending on your skills, removing the back cover (the bottom lifts after removing the four screws and then you need to twist and tug the top to get the back off) and clean the bottom 1/4 of the phone using a toothbrush soaked in isopropyl alcohol. Then dry completely with hot air, a hair dryer will suffice.
10 out 10 non-charging KG-220 seem here in the last six months were all fixed using this method!
The classic indication is when plugging the charger into the switch on phone, the handset turns off.
Dec 11, 2007 | LG KG220 Cellular Phone
Unable to place a call or receive a call on treo 650
May I know since when the problem occur and what's happen if you tap phone application?
Nov 07, 2007 | Palm Treo 650 Handheld
02 xda orbit
o2 xda orbit phone not working,...totally dead phone..kindly help for repair....
Sep 14, 2007 | Computers & Internet
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
277 people viewed this question
Top Palm Cell Phones Experts
fhonwizards
wayne chamberlain
Marvin
Marvin
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
