Question about AEG Lavamat 12710 Front Load Washer / Dryer
Lavamat 12843 no power
No display on machine control panel .Power is available at machine inside under top cover.
  • 4 Answers
Maybe a bit late by now noting your question date.. If you have L & N from supply through suppressor to pcb it could be board u/s but well worth checking for low insulation on elements as oddly this can cause the display not to light!. If you don't have a suitable meter disconnect all wires to elements and see if it works.
Posted on Jun 04, 2014
3 Suggested Answers
SOURCE: PC board of Lavamat 42260 Top Loader washing
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
Posted on Apr 15, 2009
caroldon
  • 17129 Answers
SOURCE: AEG Lavamat 64810. No error
The fault has been described well by you and it is confirmed that the motor is not running. Now eventhough you have mentioned a clean chit to the control panel I would like you to take a voltage check on the motor when it is in wash cycle.
If the power comes on and there is no motor action then it is confirmed that the motor is fauly. But if there is no output of the voltage to the motor from the controller, the it is possible that the controller is faulty.
If motor is humming and is of single phase type, check the capacitor and replace if motor is humming and not running.
.I am sure you can sort this out having come this far.
Hope my tip helps
Posted on Aug 28, 2010
How do you take out the filter on a AEG LAVAMAT, 12843 VIT.
HI,SOME TIMES A COIN OR HAIR GRIP CAN JAM UP THE MAIN PART OF THE FILTER,IF YOU CAN IS TO REMOVE THE WHOLE PUMP TO CLEAN IT OUT,POWER OFF BEFORE YOU DO IT ,THANKS.
Jul 04, 2014 | Hotpoint WMA54 Front Load Washer
Power up a Xerox 8860 MFP printer
if the control panel display is completely blank but the printer works, you have a faulty panel. I can order it, feel free to contact me, its possible xerox will still cover this under warranty. Call xerox tech support, tell them the issue and see if the control panel would still be covered under warranty eventhough your machine is out of warranty. instructions come with replacing the part.
Mar 04, 2014 | Xerox Phaser 8860MFP Printer
I can not boot I get power saving mode message on my monitor how do I boot
Click on "Start" in the lower left-hand corner of the desktop. From within this menu, select "Control Panel." Double-click on "Power Options" located inside the Control Panel. Turn off the power saver plan by selecting one of the other power plans listed inside the Power Options dialog box. If there are no other power plans available, you can create one. Create an alternate power plan by clicking on the "Create a power plan" link on the left-hand side of the Power Options dialog box. This will open another window allowing you to create a power plan of your own. Select the type of power plan that you want, and enter a customized name for this plan. Once you have done this, click "Next." You will then be able to edit the plan's advanced settings to include how it handles the display, sleep mode and brightness settings under the battery and when it is plugged in. Hope this helps.
Dec 17, 2012 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Lcd quit working after only two loads of clothes. Power button comes on and chimes, wash light comes on. Nothing else works. How do you fix it?
replace the board on unit.... if you have already unplugged for a few minutes and tried to reconnect you may have a bad pc board on unit/display////// lg is notorious for molex plugs or connections that could be a issue depending on how old unit is.... if you go to back of unit there are 2 maybe three screws to remove the top of cover by pushing top to rear of unit... then inside you should see control boards and all... you can also remove a screw on each side of display panel and pop display/touch pad off and check connections under it.... if all looks good i would say got a bad control board.....
Mar 05, 2011 | LG WM3885HCCA Washer
Cant find my manual, but the error code is F-21
Remove your service panel and you will find your tech sheet tucked neatly away inside a plastic keeper in that service panel.
The F-21 on your model is:
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Remove the top cover:themobilian_1466.jpg
Check your connection for corrosion or soap dripping into the top of the machine. It is advised not to set anything on top the washer that might drip into the controls.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My LG washer won't turn on. When I press the power button, you can here the power on jingle but the display does not turn on and when I turn the cycle selector nothing happens. This a fairly new washer a...
replace the main control unit under the inits top cover in the left rear top corner & inside the plastic cover if when you open the cover that protects the mainboard from water spray(if theres NO RED LED lit on the control board) then its the board that needs replacing,if it has the LED lit then run the diagnostics per the tech sheet located inside the machine and it will tell you whats actually wrong,next step is to replace the touch pad located around the selector knob on the front face of the unit
Jan 27, 2011 | LG WM2077CW Laundry XL Front Load...
Dryer not working, PF fault.
The fault code PF means a power failure occurred or the power to the dryer was interrupted by any means while it is running. The interruption can be due to a power outage/failure or a power cord loose connection to the electronic control board. Pressing the Pause/Cancel button clears out the display; otherwise, unplug the dryer then let it sit for at least 15 minutes.
Remove the three hex-head screws from the rear flange of the dryer top cover to access the machine control electronics and check the power cord connection if the issue is not resolved above or if the fault code keeps on popping up. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover. Lift the rear of the top cover and slide it back so the tabs clear the catches on the bracket, and remove the cover from the unit. Make sure that the tabs slide under the bracket catches when you reinstall the top cover.
Remove the three screws from the machine control electronics board bracket and pull the bracket away from the side of the dryer in order to access the connectors. Visually check P1 harness, the five-wire harness on the upper left corner of the machine control electronics where the power cord connects and make sure the connector is fully inserted into the electronic controls and the terminal connections are clean. Reseating the connection several times will help clean off dirt and corrosion build up in the connection
The
machine control electronics definitely needs replacing if the issue is not addressed by the outlined procedures above.
Jul 18, 2010 | Whirlpool GEW9200L Electric Dryer
Hoover vision hd washing machine was working then tripped power. checked plug socket, plug fuse all working. there is power to machine but no power showing on control panel. could it of blown a relay etc?
Could be faulty door interlock, as nothing will work until this activated..
On the other hand, could well be power module or display module that is faulty.
The only thing thing you can do at the moment is to remove the top cover, and see if there is anything obvious looking in at the top
Hope this helps.
Feb 01, 2010 | Washing Machines
Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid. plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
Sep 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 12710 Front Load Washer / Dryer Logo
145 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
