Question about Ricoh Aficio CL3500N Laser Printer
Rc gate connection error - Ricoh Aficio CL3500N Laser Printer
I live in Retreat , Cape town . where can I find remotes for this garage door opener units. And what is the cost.
as I live in the US I have no idea what kind of stores are there , but here most home improvement stores carry them .
Jan 29, 2017 | Building Materials
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
How to fix error 7a on a billcon d-551
I know this is an old post. But the Error 7A on a model D-551 is a "Gate Up" problem. The gate is what diverts the note to the reject pocket or the lower stacker area. 1) Check that the gate flap can be moved smoothly. The solenoid that electrically moves the gate flap is connected on the main control board (under the right cover) at CN14. Re-seat the plug cable. Also clean ALL the count sensors inside the machine. Good luck
May 14, 2014 | Billcon D-551 Mixed Money Counter 2 Pocket
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Very slow system boot up and report for Express Gate error code C800002
What the error is telling you is there is an error on trying to install Express Gate. and best to install on a USB drive. If you must install it on the hard drive. you will have to set to IDE not AHCI or RAID mode. ExpressGate has to be installed on the SATA hard disk is connected to the red SATA port. (Other color slot can not be used)
May 07, 2009 | Computers & Internet
Ricoh Aficio CL3500N Laser Printer Logo
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
