Question about Tools & Hardware - Others
How to unjam nail in second fix hihachi gas gun
  • 23 Answers
SOURCE: senco 600 framing nailer / double hitting(nailing)
double nailing is usually caused when you apply to much pressure on gun causing it to fire on the recoil lighten up just tap it on the surface to be nailed
Posted on May 11, 2009
rowdy45176
  • 2176 Answers
SOURCE: 2 nails shooting at once from nail gun
Could be couple problems. Are you using the right nails for this tool the right guage and degree? Is the nose worn allowing 2 nails to be able to shoot. Give me the model number and brand and I will try and find a print for this tool with firther suggestions, but these would be the most common
Posted on Sep 27, 2009
  • 10865 Answers
SOURCE: bostitch nail gun number SB-21n1 is jammed and
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Posted on Jan 12, 2010
  • 67 Answers
SOURCE: Paslode finishing nail gun won't fire? Battery is
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
Posted on Sep 13, 2010
puertobori
  • 7733 Answers
SOURCE: Dewalt 51844 framing nail gun, Leaking air out
Go to eReplacementParts.com : Power Tool Parts and Tool Repair and find a diagram and the parts you need.
Posted on Nov 02, 2010
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
Tip
Power nail/staple gun
The worst pneumatic nail/staple gun is still better than the best electric nail/staple gun.
on Oct 26, 2013 | Chicago Pneumatic Air Tools & Compressors
How do I unjam my arrow electric staple gun
I have used a small screwdriver to pull out staples but occasionally had to disassemble to gain access - I think there may be just one screw to remove bottom piece
Nov 02, 2014 | Arrow Fastener ET2025D 3 In 1 Electric...
How do I unjam a porter cable BN200SB nail gun
I suggest that you make sure that there is no air he tool so, remove the air supply. Then if you remove the cover from the nose (Making sure that you also take out all the unused nails first) it should allow access to the front nose plate. If you remove this, it will allow you to carefully remove the nail. While you're at it, check that the driver blade tip doesn't have any burring or damage to it. If so, you might need to fettle it back into shape or, replace it?
Sep 14, 2014 | Porter Cable Tools & Hardware - Others
Nail broken off in the gun can not unjam, what is the procedure to remove broken nail?
The easiest and most effective way is to use a hammer and a long flathead screwdriver that you don't mind messing up. Place the nail gun upside down on a flat surface with the nose pointing up. If you have a vise it is advisable to put it in the vise.(Use a piece of rubber or a rag to secure) Use a flashlight to locate the driver inside the nose of the gun. Place the flathead screwdriver at an angle across the driver and use a heavy hammer. Give it a good whack. Do not hit in repeated motions. Hit one good whack and see if the driver moved then set up for another and give it a good whack. You should be able to dislodge the nail head in this way. Caution, be aware of where your hands are at all times. It is not uncommon to hit your hand or cut your hand on the nail gun when trying to do this.
Sep 22, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
I have a craftsman nailer full head framing gun. There is a jam of 2 nails in the cylinder. How do you unjam the gun
On that nailer, you have to remove the nail Magazine. And then clear jam thru the sloted open side. And then put the Magazine back on. Usually one big bolt on each side of the nose and 1 or 2 bolts on the rear body.
Aug 25, 2009 | Air Tools & Compressors
Tools & Hardware - Others Logo
16 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
