Question about Dell Latitude E6420 Laptop Computer 500 GB Hard Drive
HOW TO REMOVE SYSTEM PASSWORD - Dell Latitude E6420 Laptop Computer 500 GB Hard Drive
  • 641 Answers
Hi Crispine,
You may want to check this site in order for you to resolve your issue and get some tips as well. Hope it helps.
Want to Remove Your Windows Password Read This First
Posted on May 08, 2014
Bypass password
There are two forms of rejection> The operating system (Windows for example) and the System password. The System Password won't allow you to start the computers Operating System. If so, a rest must be done by a Technician. If it is a Software password; you can get a program called PowerSuite that has a password deletion program to remove existing code.
Dec 21, 2013 | Computers & Internet
HP MINI 110 SYSTEM PASSWORD FORGOTTEN
to remove your password in laptop you must remove the battery then remove the small A+ betray its inside so its dangerous to do it
Give it to any PC shoe to do it
Dec 13, 2012 | Computers & Internet
Lost windows password
To get more helpful info, u can search the method source:
Windows Password Reset Std/Windows Password Reset Pro/Windows Password Reset Deluxe,and have a try.
Follow my steps:
Step1:Download and install Windows Password Reset Deluxe.
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove Windows Password.
Hope it can help.
May 12, 2012 | IBM ThinkPad X40 Notebook
Help to restore the computer to normal (Bios Password)
RTM - Read The Manual
I found the info below in your manual online. You will need to reset the jumper on the motherboard to remove the password.
Admin Password (Not Set default)
Displays the current status of your system setup
programs password security feature and allows you to
verify and assign a new admin password. The Admin
Password may be disabled by a jumper on the system
board.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Passwords.
Clearing Forgotten Passwords (the manual shows a picture of this)
1 Remove the computer cover.
2 Locate the 2-pin password jumper (PSWD) on the system board. By
default, Pin1 and Pin2 should be connected. You will need to remove the
jumper and boot the system, as follows.
3 Remove the jumper.
4 Replace the computer cover.
5 Connect your computer and monitor to electrical outlets, and turn them on.
6 After the Microsoft Windows desktop appears on your computer, shut down your computer.
7 Turn off the monitor and disconnect it from the electrical outlet.
8 Disconnect the computer power cable from the electrical outlet, and press the power button to ground the system board.
9 Open the computer cover.
10 Locate the 2-pin password jumper (PSWD) on the system board and
attach the jumper to reenable the password feature.
11 Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network wall jack and then plug it into the computer.
12 Connect your computer and devices to electrical outlets, and turn them on.
NOTE This procedure enables the password feature. When you enter system setup (see "Entering System Setup" on page 79), both system and administrator password options appear as Not Set meaning that the password feature is enabled but no password is assigned.
13 Assign a new system and or administrator password. Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network device and then plug it into the computer.
14 Connect your computer and devices to electrical outlets, and turn them on.
Apr 23, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
I want to remove system password
Hi, If you want to remove the system or Bios password then clean the Bios. Reconfigure the motherboard jumper settings. It will remove Bios password. If you want to remove user password then go to the user accounts in control panel open the user by double click and remove the password. If you can't login then login by safe mode in administrator account and do the same as before.
Oct 17, 2011 | Dell OptiPlex 360 Desktop Computer
How to bypass a dell dimension b110 password
It's not so clear since you haven't mention which password, whether Bios password or system password. If it's Bios password, remove the Bios battery and leave it outside for few mins and reinsert it. That will solve the problem. But if it's system password (password to be typed in when you are logging on to your system), it depends on the operating system on how to bypass it. For windows XP it's easy with some key strokes but for win vista and win 7 it would be much tougher since higher security feature is implemented with these operating system. Let me know if your problem is the system password with the operating system mention in your comment. Good luck.
May 14, 2010 | Dell Dimension™ B110 PC Desktop
Forgot start up password
if the password comes when the system is turned on then it can be removed by removing the cell from cabinet of your system and if you applied the password at the OS startup then press ctrl+alt+del and login as administrator without typing the password
Nov 08, 2009 | Computers & Internet
Bios password reset
dear,
remove power cord from system.
pl set cmos clear jumper on motherboard and power on your cmos password is disable.
May 05, 2009 | Dell Microsoft Windows XP Home Edition
Travelmate 260 bios password how do i remove
to remove the bios password just plug out the system battery (It will be a small thin cell inside ur system).
remove it for abt 5 second and then again put it back and restart ur system.
there u go ur bios password is gone.
Jul 20, 2008 | Acer Computers & Internet
Dell Latitude E6420 Laptop Computer 500 GB Hard Drive Logo
83 people viewed this question
Alun Cox
