Question about Britannia Kitchen Ranges
Britannia cooker, Mod S1-15GEB-MB-BR,Fan oven in right hand electric oven is not heating up,have made sure red hand is displayed on the clock,all other cooking options work,thanks
  • 1462 Answers
SOURCE: Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Posted on Mar 31, 2007
SOURCE: electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Posted on Jul 28, 2007
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Jun 16, 2012 | Britannia SI10T6L Dual Fuel (Electric and...
Fan bake on smeg oven not heating ,mod SA 9066XS
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 02, 2012 | Smeg Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Dec 30, 2009 | Ovens
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Id number for range
The id number is in the right hand oven on the right. It sounds ans though the cooker is a 90 or 100 wide with chef top or fish burner. An instruction bookcan be sent in pdf format by contacting www.britannialiving.co.uk
Dec 21, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Britannia Kitchen Ranges Experts
James Gettemy
Bill Boyd
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
