Question about Franke Plumbing
How to install a new diverter for Franke FF800 faucet
Have 65320C sprayer, and faucet Franke FF800D both retired items, company sent part 802.379 FF=1350 Diverter kit, no documentation for installation. Can you help, was installed in home seven years back, plumber can't help. The faucet stopped working, only sprayer works, but have to keep flow low, as not to cause air in line, then have to wait for pressure to disapate in the line before spraying restores. Any suggestions when I can find instructions for installations and repairs.
3 Suggested Answers
  • 49 Answers
SOURCE: No water passes from faucet to hand sprayer
try soaking it in some CLR calcium lime and rust remover .
Posted on Mar 18, 2009
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
Installed new kitchen faucet. When water is first turned on, fill lines jerk and make noise. Also when water turned off, it takes several seconds for water to stop running. What is our problem?
tis more than likely a defective diverter. diverter if you have a side sprayer. If you don't have a side sprayer, check the technical info to see if your faucet has a diverter anyway.
wherever you bought it tell them and ask for a replacement.
Does it do it with only cold? hot?
Feb 16, 2018 | Plumbing
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
Installed new kitchen fauce. no water running though faucet but is running though sprayer. what could be the problem?
Sounds like the diverter that transfer water from faucet to sprayer is bad or stuck. Try turning water off and removing handle and remove spout to acess the diverter is near the base of the body of the faucet. Below is a link with a exploded view that will show you a parts breakdown hope this will help.
http://www.moen.com/shared/pdf/ca87530pt.pdf
Jun 26, 2011 | Moen 87530 Touch Control Single Handle...
I have an older delta faucet. Sprayer does not work well.
i believe the faucet shaft,..they usually are on delta models i've worked on,........your best to get a full rebuild kit for this and do the whole thing when you've got it down,.....good luck, cracklin joe
Jan 10, 2010 | Delta Faucet #RP320 Divert Assembly
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water still comes from faucet while using kitchen sprayer
compare old diverter to new one look for different wear on the old. could be bad manifold and with no receipt could be challenge just keep complaining to them works most of time .
Mar 24, 2009 | Plumbing
Mar 15, 2009 | Kohler Model 10430: FortĀ® Single-control...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
101 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
