Question about Fisher and Paykel Refrigerators
OK I have the RF610A fridge on top and freezer below in french door arrangement.
In model RF 610A freezer is cold and fridge is not. Both fridge and evaporator sensors replaced- no change. Did notice evaporator coils with ice on them when switched off replacing sensor however this melted prior to switching back on. Never hear compressor running but must be working if freezer is cold -correct? Any ideas to further fix? Water is not connected and has not been for some years.
  • 2,509 Answers
Have you checked the fridge thermostat? If the thermostat is ok then you should trace the volts which operate the valve which connects the compressor to the fridge evaporator coils. If the valve is getting volts then the valve is faulty. If not fault lies with control circuitry.
Posted on May 08, 2014
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
catriver
  • 878 Answers
SOURCE: Fridge/freezer
Denis, frosting back to the compressor is usually a sign of refrigerant overcharge. The fact that you noticed one of the other lines opened could indicate a wrong charge. You will need a cfc certified tech to check this thing out. This way he can check for a proper charge, restriction or a weak pumper...Catriver..post back.
Posted on Sep 04, 2006
Sea Breeze
  • 4654 Answers
SOURCE: Compressor not running, Fridge/Freezer not
Unplug refrigerator pull away from wall. Remove cover over compressor and feel top of compressor to see if overheating or trying to start. If too hot to hold hand on top leave unplugged until we locate the problem. This could be capacitor, start relay, overload, motherboard. This can Be fixed but we need to eliminate cause before replacing any parts. Sea Breeze
Posted on Jan 23, 2010
SOURCE: Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Posted on Jul 22, 2010
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
MODEL LRS 206 GP FREEZER IS WORKING WELL AND THE FRIDGE IS NOR WORKING WHY ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | LG LTC22350S (221 cu ft) Top Freezer...
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Fridge not cooling freezer top mount ok
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
88dt
Apr 27, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
152 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
