Question about Dell Inspiron N4020
My Dell Inspiron N4020 Laptop power button don't come on when I press to boot it. what happen?
The power switch don't come
Ensure the power cable is fully inserted into the charger slot, ensure the charger itself is firmly connected to the wall and if there is a power brick in the charger ensure all parts of that are connected. It just sounds like the battery is dead.
Posted on May 08, 2014
romeetb
  • 66 Answers
SOURCE: Problem Dell Inpiron 5160
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
Posted on Dec 01, 2007
MerlinTech
  • 197 Answers
SOURCE: dell inspiron 6400 notebook wont turn on
try this with battery removed first..
plug in ac power, no battery,
then when turning on machine, press F8 to go to safe mode(pick the top option)
see how that works forya
Posted on Jun 14, 2008
zohail
  • 1223 Answers
SOURCE: Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Posted on Mar 07, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
SOURCE: Dell 1000 Inspiron won't get past start up screen, frozen
Had this exact problem on the same model (Dell Inspiron 1000) laptop. Solution was simple: remove battery, problem goes away. I guess the battery was so far gone it was hanging the BIOS on startup.
Posted on Apr 20, 2010
How do I format partitions dell inspiron n4020
Use Computer Management in Administrative Tools, in Control Panel
Jul 15, 2014 | Dell Inspiron N4020
My dell inspiron n4020 touchpad wont work
Try pressing the button to the right of the F12 key - the touchpad enable/disable key
Dec 18, 2011 | Dell Inspiron N4020
Performance is very slow of Dell Inspiron N4020 with Win7 OS. Please help me out.
Did you get this laptop with the Windows 7 installed or you upgraded from a lower version to Windows 7?
Windows 7 requires a huge amount of RAM (memory) and a good compatible video card. (because of the aero feature). If you don't meet the recommended system requriements, there is a big possiblity that your system will slow down.
If you have a good hardware and it is still slow, check your computer for possible virus infection or any application that consumes system resources. (e.g. Antivirus Software when running a full scan)
Hope this helps.
Aug 11, 2011 | Dell Inspiron N4020
NOT BOOTING WINDOWS XP IN DELL INSPIRON 1545
1. Press and hold the power button for 10 seconds. If nothing happens go to the next step.
2. Remove the battery of your laptop, then plug the power cord of your laptop directly, then press and hold the power button for 10 seconds. If nothing happens I would suggest to contact your manufacturer so that they can provide further assistance.
Jun 13, 2011 | Computers & Internet
I have dell inspiron 1525.I am from India. I have two problems. First I have a sim card slot in my laptop and ai don't know how to activate it. My other problem is serious one. My laptop unexpectedly...
Dell has a series of tests for a system's hardware called the PSA+ Diagnostics. You can run these tests by performing one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dellâ„¢ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • As for the laptop shutting down, that usually indicates your CPU (Central Processing Chip) is overheating. This is caused by dust or defective CPU fan or heat-sink.
Jun 10, 2011 | Dell Inspiron 1525 Laptop
When I press shut down, the laptop screen gets off but the power button stays on and the laptop stays warm too. I have to press power button for 5 sec to turn this thing off. When I start it I don't...
hi, when you press the power button it'll goes to sleep mode only. You can change it by accessing control panel -> power option...
thanks & regards Anas K A
May 29, 2011 | Dell Inspiron 1545 Notebook
"Dell Media Direct" on Inspiron 1525
Make sure you do not have a bootable CD or DVD in the drive. If that does not resolve, then try holding the "home" (Media Direct) button while pressing the Power button on.
Nov 02, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Inspiron 4000 problems
First, can it boot into BIOS setup? This is DEL, Esc, F1, F2, or whatever key your user manual instructs; press the requisite key immediately after pressing the power switch. Second, can it boot from an emergency recovery disk from the floppy, or a boot CD from the CD drive?
Mar 12, 2006 | Dell Inspiron 6000 Notebook
Dell Inspiron N4020 Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
