Question about Brother MFC 6490CW InkJet Printer
Does brother mfc 6490cw have bluetooth - Brother MFC 6490CW InkJet Printer
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Posted on Sep 04, 2009
Testimonial: "Thanks, 'komguy' :) !! That's helpful. I'll get hold of them ASAP! Cheers!"
  • 526 Answers
SOURCE: I have a Brother MFC 6490cw and can't Get The
if you have done a couple cleanings and it has not helped, its one of 2 things, either your ink cartridge is empty and needs to be replaced, or the nozzles are clogged on the printhead, also air can be in the turbing causing it not to let the liquid flow.
thanks adi
Posted on Dec 03, 2009
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW printer error unable to print
Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
Posted on Feb 09, 2010
pineworks
  • 4041 Answers
SOURCE: My brother MFC-6490cw injet printer does not print
Hi There
steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
pineworks
  • 4041 Answers
Hello there
I think this is down to a bit of paper sticking some where, it worth a try anyway.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Apr 29, 2010
Brother Mfc 6490cw error unable to clean 50
This is a possible printhead problem. Call brother may times they will do it was a warranty repair even after the warranty period.
May 20, 2016 | Brother MFC 6490CW InkJet Printer
Lost installation cd for my brother MFC-6490CW
Check Brother website to download drivers software: http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/dlf/download_top.html?reg=eu&c=eu_ot&lang=en&prod=mfc6490cw_all
Apr 08, 2012 | Brother MFC 6490CW InkJet Printer
I have purchased a MFC 6490CW printer in Germany. can I change the language in LCD screen from german to english on MFC - 6490CW?
Yes under settings there will be a language option, just have to go through the process in the German Language
May 22, 2011 | Brother MFC 6490CW InkJet Printer
Is Brother MFC-6490CW printer can print double sided?
No, that model does not print Double Sided (Duplex). You can see all the features and specifications here: http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
Mar 10, 2011 | Brother MFC 6490CW InkJet Printer
Where does the paper go on a Brother MFC 6490CW?
theres a menu button on the wireless printer..go to network and set the configuration from there if your using wireless just set the configuration to the existing wireless device you have and thats it...instant wireless printer connection...also check the manual..hope this helps...
Aug 28, 2009 | Brother MFC 6490CW InkJet Printer
Brother MCF-6490CW will not intall drivers with Windows 7 Ultimat
The drivers should come inboxed with windows 7 on the official final versions. Later on the drivers also will be released on brother's homepage(s), but they usually take some time before uploading drivers to the homepage when new OS' are released. Try using the Add Printer Wizard and see if you're able to find the MFC-6490CW in the list of printers available.
Apr 16, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC 6490CW InkJet Printer Logo
23 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
