Question about Xerox WorkCentre M-24 Color Copier
Where can I purchase DRUM cartridges for my Xerox Workcentre 24 as I need Magenta and Cyan immediately?
Are the drum cartridges for newer Xerox Workcentre models compatible?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Go to www.partsdrop.com or aaatoner.com
or if you want immediate supply go to your nearest xerox store and purchase it if you are in new jersey partsdrop is the wholesale dealer and they will give you drums and toners in wholesale price
Posted on Jan 11, 2015
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 42 Answers
SOURCE: Xerox workcentre 24 paper lifter problem 007-293
Go to www.thepartsdrop.com for xerox parts.
Posted on Jul 04, 2008
  • 19 Answers
SOURCE: Workcentre 24 Drum cartridge
Have you recently replaced the drum and if so does the machine not recognize the new one has been installed?
If this is the case then you should follow the steps below to replace the drum:
NOTE: Once the machine has instructed you to replace one of the drums (CMYK) then there is no way around but to replace the drum specified.
  1. Remove the new Drum Cartridge from its packaging and place it on a flat surface near the machine. Do not place the Drum Cartridge upright.
  2. Make sure the machine has stopped copying or printing, and then open the machine Front Door.
  3. Lift up on the lever marked 'A' located on the left front side of the Drum Cartridge.
  4. Pull down on the release handle to unlock the Drum Cartridge lock and access the four drum cartridges.
  5. Gently remove the Drum Cartridge (A1=Black, A2=Cyan, A3=Magenta, A4=Yellow) indicated on the Touch Screen, by grasping the light orange tab on the cartridge handle and pulling it straight out.
  6. Rest the new Drum Cartridge along with its black plastic protective shield into the cartridge slot. Make sure to load the cartridge in the direction of the arrow on the top of the shield and with the bottom of the shield resting on the release handle.
  7. Remove the tape from the top of the cartridge shield by pulling it off.
  8. Hold the Drum Cartridge shield and push the cartridge into the machine using the light orange tab.
  9. Remove the shield from the machine.
    NOTE: Make sure the cartridge guide is aligned inside the guide rail, if not reseat the cartridge. See the Related Items below for additional information.
  10. Lift up the release handle in the middle to lock the Drum Cartridge
  11. Push the lever marked 'A' handle latch down until it locks.
  12. Close the Front Door. If the Front Door is not completely closed a message will be displayed and the machine will not operate.
Posted on Nov 24, 2008
  • 60 Answers
SOURCE: How to replace the drum on my Xerox WorkCentre M151
Here's the manual for the printer. On pages 10-9 and 10-10 it walks through replacing the drum.
http://download.support.xerox.com/pub/docs/WC_M15/userdocs/any-os/en/wc_m15I_Userguide_en.pdf
Posted on Apr 07, 2009
  • 4 Answers
SOURCE: I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Posted on Jun 26, 2010
Streaky cyan, grip to back
I'm not sure which model # you have but if it's similar to the 7700 series you can try cleaning the laser window, if that doesn't change the problem it's probably the developer roller.
Mar 18, 2015 | Xerox Office Equipment & Supplies
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Actualy my copier is xerox work centre 5020. My problem is machine is indicate replace the drum cartridge. How can i solve my problem without buying drum cartridge set. Please helpme if any solution is...
Well, since the drum is a consumable, most of the copies is running life span counter. When the drum reached the life span, the message will pop out. Well, if the print out still ok, just ignore it.
Jun 27, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Jul 24, 2009 | Xerox Office Equipment & Supplies
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre M-24 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
